17266 Discussions
Can't Generating TB for AXI Streaming Intel FPGA IP for PCI Express.
Albert_Waissman
I am using Quartus version 24.1.0
Trying generate TB for this IP from IP Prameter Editor, getting following Error:
Error: TB_Gen: intel_pcie_ss_axi_0_pcie_tb has no class
Error: Error: TB_Gen: intel_pcie_ss_axi_0_pcie_tb has no class
Any suggestion on what wrong?
anonimcs
New Contributor III
While Generating HDL, did you enable the option to generate simulation files as well ?
RongYuan
Use the IP Catalog to create an IP variant then generate an example design in that IP menu.
Make sure the Simulation is selected before you click "Generate Example Design"
Rong
RongYuan
This case is set to close.
Rong
