I'm using Quartus 10.0. When I change the the "Compile test bench" drop-down list , the "Apply" button is still disabled. And It always runs the first test bench. I've checked the .qsf file. It is not changed too. Does anyone have this issue too?Link Copied
i run into the same thing here, if you have mutliple testbench setups in NativeLink under Assignments > Settings > EDA Tool Settings > Simulation, it doesn't seem possible to select the 2nd test bench
editing the .qsf EDA_NATIVELINK_SIMULATION_TEST_BENCH statement to your 2nd testbench name should be a work around. have you tried this?
