17267 Discussions
Cannot create component from template interface in Platform Designer
IKate
Hi!
i try to create a component into Platform designer which includes an interface in system Verilog.
I get the error "Error: Verilog HDL or VHDL XML Interface error at apescore.sv(15): port "i" has an unsupported type File: d:/.....sv Line: 15"
Synthesis works fine.
in order to reproduce the issue you can try the template by:
right click on empty .sv->insertTemplate->Contruct->DesignUnit->Interfaces->masterSlaveExample
This template has an issue with the generic interface, but once you fix that, it gives the same error when you try to create a component.
What is unsupported? Is there a workaround?
thanks
Ioannis
RichardTanSY_Altera
Quartus Standard has limited support in SystemVerilog and you can check the Quartus Prime Standard Edition Help version > Quartus Prime Support for SystemVerilog, for the list of supported constructs.
Do note that you need to install the Intel® Quartus® Prime Help to access it.
KDB Link: https://www.intel.com/content/www/us/en/support/programmable/articles/000097917.html
For Quartus Pro, you can check it online.
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#hdl/vlog/vlog_list_sys_vlog_d1627e1435.htm
Richard Tan
RichardTanSY_Altera
Which Quartus version are you using? Standard or Pro?
Richard Tan
IKate
i  have access to both standard and Pro versions.
I see that in Pro it works.
Does this mean in Standard i can only do components with simple ports?
Is there a table describing all the features of Pro version that Standard does not provide?
best regards,
Ioannis
RichardTanSY_Altera
Richard Tan
RichardTanSY_Altera
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
IKate
HI Richard,
Yes, it was helpful, i do not need anything else.
Ioannis
RichardTanSY_Altera
Thank you for acknowledging the solution provided. I'm pleased to know that your question has been addressed.
Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Thank you and have a great day!
Richard Tan
