17258 Discussions
Cannot instantiate Cyclone V Hard Processor System in Platform Designer 18.1
SBasa5
Software: Platform Designer 18.1 Build 625
Os: Centos 7.6
Steps to reproduce:
  1. File -> New System...
  2. From IP Catalog select Library / Processors and Peripherals / Hard Processor Systems / Arria V/Cyclone V Hard Processor System
  3. click Add...
Got error message and all in/out ports are missing in 'System Contents' view.
Error:
unsaved.hps_0: list element in quotes followed by ":" instead of space
  while executing
"llength $db"
  ("if" test expression)
  invoked from within
"if {[llength $db] != $PASSED_LIST_SIZE} {
  return 0
  (procedure "::pin_mux_db::load" line 26)
  invoked from within
"::pin_mux_db::load $device"
  invoked from within
"set load_rc [::pin_mux_db::load $device]"
  (procedure "ensure_pin_muxing_data" line 20)
  invoked from within
"ensure_pin_muxing_data $device_family"
  (procedure "validate" line 4)
  invoked from within
"validate"
  (procedure "compose_logicalview" line 8)
  invoked from within
Warning:
unsaved.hps_0: This module has no ports or interfaces
Comment:
I have checked ip/altera/hps/util/pin_mux_db.tcl
My guess is that run_quartus_tcl_command does not handle "@" in my ${quartus_script_path} = /home/xxxyyy123@zzz.local/intelFPGA_lite...
Any quick workaround?
SBasa5
Managed to find workaround by myself:
When working on linux.
It looks like Platform Designer scripts does not handle @ in the installation directory ( $QSYS_ROOTDIR)
Reinstalled somewhere else eg.: /opt/quartus
Comment:
Actually it is mentioned in documentation:
No special characters or symbols, such as !$%@^&*<>,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
EBERLAZARE_I_Intel
Also, it is a good practice to not use space instead use underscore "_"when renaming/creating projects folder names.
The same rule applies when you are going to use the SoC EDS Command Shell.
