As usual, being a newbie to Quartus tools I am running into initial set up issues. I am trying to open Quartus software from command line and here's the script I am using to open get into NIOS2SDK shell (copied from http://www.nioswiki.com/operatingsystems/uclinux/quartusforlinux):
#!/bin/bash# Run this for a Nios II SDK bash shell export LM_LICENSE_FILE=1800@localhost SOPC_KIT_NIOS2=/opt/altera8.1/nios2eds export SOPC_KIT_NIOS2 SOPC_BUILDER_PATH_81=/opt/altera8.1/nios2eds export SOPC_BUILDER_PATH_81 unset GCC_EXEC_PREFIX QUARTUS_ROOTDIR=/opt/altera8.1/quartus export QUARTUS_ROOTDIR export PERL5LIB=/usr/lib/perl5/5.10.0 bash --rcfile $QUARTUS_ROOTDIR/sopc_builder/bin/nios_bash But I am getting "Cannot open X display" error. I have read posts in this forum which say that we do not need X11 library trick, so can some one guide me as to what could be the possible reason and what variables I can check? I tried to remotely connect to the machine which has quartus software, it din't gave me X server error though, so could it be the DISPLAY variable that needs to be set right? volatileLink Copied
As far as I understand, you are in the right direction i.e it is not the problem of QUARTUS, but that of Xdisplay.
Hey Thanks for the reply.
I was not using the GUI so I started it with "startx" command and things started working fine. BUt I am still not able to understand the problem it was having without having the GUI up?- Mark as New
bash-3.00$ echo $DISPLAY
bash-3.00$ bash --rcfile $QUARTUS_ROOTDIR/sopc_builder/bin/nios_bash
Welcome To Altera SOPC Builder
Version 9.0, Built Wed Feb 25 21:35:53 PST 2009
mine seems to work over ssh.
