Capturing Data
hi. Timing simulation is done for the sin waveform. The output is only valid when the signal out_valid is high. So, can i just capturing the valid output signal and save it using Quartus II?
Or i have to manually write a program to filter out unwanted output?
Could you post your code?
Do you mean the verilog code? Is it related to it?
Thanks to all
