17268 Discussions
Channel has no point Connection
I just got a weird error when trying to build my OpenCL code with aocl:
Error Channel has no point connection: ID= in_channel_a avm_channel_id_in_channel_a_write connection misin, or optimized away
I simplified the code down to the following, which still produces the error:
# pragma OPENCL EXTENSION cl_altera_channels : enable channel uint2 in_channel_a __attribute__((depth(1))); channel uint2 in_channel_b __attribute__((depth(1))); channel uint2 out_channel __attribute__((depth(1))); __kernel void in_streamer_a(__global const uint2* in, uint n) { for(uint i = 0; i < n; ++i) { write_channel_altera(in_channel_a, in); } } __kernel void in_streamer_b(__global const uint2* in, uint n) { for(uint i = 0; i < n; ++i) { write_channel_altera(in_channel_b, in); } } __kernel void out_streamer_a(__global uint2* restrict out, uint n) { for(uint i = 0; i < n; ++i) { out = read_channel_altera(out_channel); } } __kernel void simplified_worker_kernel(uint n_steps) { for(int i = -1; i < n_steps; ++i) { uint2 write_data; uint2 current_a; uint2 current_b; current_a = read_channel_altera(in_channel_a); current_b = read_channel_altera(in_channel_b); write_data = current_a + current_b; write_channel_altera(out_channel, write_data); } }
As far as I can tell, each channel is read at exactly one place and written to at exactly one place. The connections should be obvious. What am I missing?
I seem to have found the issue. When I change the loop from
to
for(int i = -1; i < (int)n_steps; ++i)
The error disappears.
This means the compiler evaluates "(int)-1 < (uint)0" as false. As a result the entire Loop is optimized away, so in_channel_a for example is never read. I still think this is a compiler error though, does anyone here know what the OpenCL spec says about signed-unsigned comparison?
what is your n_steps declared as? let say if you place i = 0 , it this work?
for(int i = 0; i < n_steps; ++i)
Yes, that works. Casting to int works too. For my personal needs the problem is solved, but I'm still wondering why the error occurred in the first place. I'm sure I won't be the last to encounter it.
