17252 Discussions
Check two different clocks
I have two clock signals: clock_50 (50MHz) and clock (16kHz). Now I want FPGA to do three commands within each clock (16kHz), the commands are done in one clock_50 (50MHz).
I tried but it doesn't work. The idea is the same following lines, but I dont know how to code it
always @(posedge clock) begin always @(posedge clock_50) begin //do a command //do a command //do a command end end
Could you please help me?
You should consider only the 50MHz faster signal as the 'real' clock.
Use a single always @(posedge clock_50) . Inside this process latch the 16kHz signal into a register and whenever you spot a change to state high trigger your 3 command sequence.
Thank you for your reply.
But I want to generate 3 sub-clocks . I tried
always @(posedge clk or negedge rst_n) begin if (!rst_n) begin // reset the registers count = 0; end else begin count_cal = 5'b00000; // reset end end always @(posedge clk_50 or negedge rst_n) begin if (!rst_n) begin // reset the registers flag_cal = 0; count_cal = 0; end else begin if (clk) begin count_cal = count_cal + 5'b00001; if ((count_cal > 1) && (count_cal < 7)) // flag_cal <= flag_cal + 1'b1; else flag_cal <= 1'b0; end end end always @(posedge flag_cal or negedge rst_n) begin // this is to do 3 commands
However it cannot elaborate successfully.
@Cris72
As you said I just do some commands within a hafl of clock cycle, not within the whole clock cycle
