- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi everyone, :cool:
I need help, do anyone here know how to clean unnecessary files or old files automatically from quartus, such as *.rpt file, *.summary and also wlf file on ModelSim. Files that can be generated again when compile operation executed. My project grow larger everytime I edit and recompile the project, especially when I added new testbench and perform new simulation. It eat to much space on my disk. Thank you,... :) :)링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I don't believe that Quartus currently has a "clean" function. I know ISE does. I typically manually delete things.
Jake- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks Jakobjones,
anyway, is this same for ModelSim..? For Altera developer, maybe you want to consider about adding this feature for next quartus release. Sometime I confuse selecting file when I browse file to be opened in external text editor because there are too many files, reducing unnecessary file perhaps will help us.. Thanks again,...- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Typically you only need .sdc .qsf .qpf .srf .qip
I keep my source files in a different directory from the quartus project. This allows me to keep the source directory clean. I used different project directories for different tools, this allows me to use/try multiple Quartus and modelsim versions. I need this because of some Quartus 10.0sp1 regressions.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
try going to Assignments > Settings > Compilation Process Settings and check Save project output files in specified directory. you could call the directory output for example
then you can remove db/, incremental_db/, output/, and simulation/ to clean a project- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks for all,
Amilcar, saving source file in different directory sound good idea. Thepancake, how about assignment setting, in which file our FPGA assignment setting saved? It will be problem if it also generated to output folder or somewhere else we don't know and we delete it, we need to assign again and again each time we clean our project. thanks,...- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
the .qsf should still be saved to whatever directory the .qpf is saved to. it won't put the settings file into the output/ directory
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I think, a *.qar archive reduces the project to it's essential files only.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thepancake, so our FPGA assigment or Project configuration saved in *.qsf file? Ok, I got it thanks...
FvM, I think *.qar is used if our project is finish and we want to store it, but if we haven't finished it, it will be problem if we have to extract it each time we want to edit our project. Thanks,...- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Of course you have to archive and restore the project to "clean" it, but the archiver does exactly what you intend, keeping those files that are referenced in the project, also if they are not explicitely included in the project file list. I'm not aware of another tool with this functionality.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I see,.. thanks for the idea. I really appreciate that...
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
...if you have .sopc builder files/wrappers tha you have created to import into your design in a user library, these files are NOT included in a QAR file automatically. Not certain if there is a setting that will allow these to be pulled in or not...
my $.02 crayner dff
