17255 Discussions
Code Check - Traffic Simulation
Hey guys,
My program seems to be stuck in the first step of the State Machine and I cannot for the life of me figure out why, I suspect a problem with the counter?
Any help is appreciated.
counter:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
library UNISIM;
use UNISIM.VComponents.all;
entity Counter is
Port ( reset : in STD_LOGIC;
clear : in STD_LOGIC;
clock : in STD_LOGIC;
counto : out STD_LOGIC_vector (9 downto 0); -- count output
finish : out STD_LOGIC
finish2 : out STD_LOGIC
end Counter;
architecture Behavioral of Counter is
signal count_i: std_logic_vector (9 downto 0); -- 9 bit timer appropriate for 100Hz required speed
signal cen: std_logic; -- count enable
begin
counto <= count_i;
cen <= '1'; -- start count enable
process (clear, reset, clock) begin -- begin process
if (reset = '1') then -- if reset begin count to as if EW car has been there for a 'long time'
count_i <= "1000000001";
elsif rising_edge (clock) then -- on rising edge of clock
if (clear = '1') then
cen <= '1'; -- if cleared begin counting
count_i <= "0000000001";
elsif (cen = '1') then -- when count is enabled count up from 000000001
count_i <= count_i + "000000001";
if (count_i >= "1000000001") then -- if minimum time is reached stop counting and wait for an input
cen <= '0';
finish <= '1';
if (count_i >= "0000100001") then
cen <= '0';
finish2 <= '1';
end if;
end if;
end if;
end process;
end architecture Behavioral;
state machine
library IEEE;
library UNISIM;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity StateMachine is
Port (
carNS : in STD_LOGIC;
carEW : in STD_LOGIC;
finish : in STD_LOGIC;
pedNS : in STD_LOGIC;
pedEW : in STD_LOGIC;
pedo : out STD_LOGIC;
clearo : out STD_LOGIC;
lightsEW : out STD_LOGIC_VECTOR (1 downto 0); -- controls EW lights
lightsNS : out STD_LOGIC_VECTOR (1 downto 0); -- controls NS lights
pedcount : in STD_LOGIC_vector (7 downto 0));
end StateMachine;
architecture Behavioral of StateMachine is
type StateType is (greenNS, amberNS, redNS, greenEW, amberEW, redEW);
signal state, nextState: StateType;
begin
SynchronousProcess: -- execute all at once
process (clock) begin -- only list clock, program auto fills required variables
nextState <= greenEW; -- start at green EW light
lightsEW <= "10"; -- car EW light green (10)
lightsNS <= "00"; -- car NS lights red (01)
case state is
when greenEW => -- when car EW is green (10)
lightsEW <= "10"; -- Good up to here
if (finish = '1') then -- if count is above 1000000001 and a car is present on NS road then set EW light to amber
if (carNS = '1') then
nextState <= amberEW;
clearo <= '1'; -- begin amber state, stop counting
else -- else remain green for EW
end if;
end if;
if (pedNS = '1') then -- if NS pedestrian button pressed
else
nextState <= greenEW; -- else remain green for EW
end if;
when amberEW => -- when amber set lights to amber (01)
lightsEW <="01";
if (finish2 = '1') then -- if count is above 0000100001 and a car is present on NS road then set EW light to red
nextState <= redEW;
clearo <= '1'; -- begin red state, stop counting
end if;
when redEW => -- when red set lights to red (00)
lightsEW <="00";
if (finish = '1') then -- if count is above 1000000001 move to green state for NS road
nextState <= greenNS;
end if;
when greenNS => -- when in green state set NS car lights to green (10)
lightsNS <="10";
if (finish = '1') then -- if count is above 1000000001 and a car is present on EW road then set NS light to amber
if (carEW = '1') then -- if car present on EW road,
nextState <= amberNS;
else
nextState <= greenNS; -- else stay green
end if;
end if;
if (pedEW = '1') then -- if EW pedestrian button pressed
nextState <= amberNS; -- begin amber state, stop counting
clearo <= '1';
else
nextState <= greenNS; -- else remain green for NS
end if;
when amberNS =>
lightsNS <="11"; -- set NS lights to amber (11)
if (finish2 = '1') then -- if count is above 0000100001 set NS lights to red
nextState <= redNS;clearo <= '1';
end if;
when redNS =>
lightsNS <="00";
if (finish = '1') then -- if count is above 1000000001 set NS lights to red
end if;
end case;
end process;
process (reset,clock) begin -- begin process
if (reset='1') then -- if reset go to state greenEW (first state)
state <= greenEW;
elsif rising_edge(clock) then -- else, if on a rising clock edge move to next state
state <= nextState;
clearo <='1'; -- stop counting
end if;
end process;
Your counter seems to be ok, but what are the values of the input?
Actually just realised that all the light settings are wrong.. From testing, should be as follows:
11 is green (car and pedestrian)
10 for green (car only)
01 for amber
00 for red
Clock is at 100Hz
Will update with nicer code and added comments in a second.
Updated with commented code and fixed up some things.
Ok, but what are the values of finish, carNS and pedNS? and what should happen if finish = '1' and carNs = '0'? or if both are 0 and pedNS is 0 as well? I think you have a few unspecified cases here.
--- Quote Start ---
--- Quote End ---
The values of carNS etc should just be 0 and 1 - they are tied to inputs on a module, on a breadboard.
Finish becomes 1 after account exceeds 1000000001.
I hope this answers your question :P
My question is: where is the testbench code?
Second question: why have you put clock in the state machine sensitivity list, when it is clearly not a clocked process? and the comment is worrying, because it shows lack of understanding of VHDL:
Quartus wont do any auto-filling for you. It will throw warnings about missing signals (note - not variables), but it ignores sensitivity lists, so you wont see a "problem". If you had a testbench, you would see that you would get many problems.
thurdly - you state machine proces produces latches - these are not recommended. You need to assign all signals in ALL cases in an asynchronous process (it is not synchronous, it is asynchronous, despite your comments).
Testbench code apparently was not needed.
I did receive warnings but to me it read as though it was populating the sensitivity list with the inputs and outputs listed within the code.
In then end I just decided to scrap the whole thing and start from scratch, end result was pretty close to what was required.
Thank you for the input though, I have only done VHDL for about 2 weeks now and electronics is hardly my forte, more of a maths and programming man myself.
--- Quote Start ---
--- Quote End ---
