17253 Discussions
Command-line check for available licenses
I want to block fitter until there is an available license, otherwise the fitter fails.
How do I check for available floating licenses in general when I run Quartus tools in command line.
There is a way to do it in GUI. In Tools->"License Setup Page" there is a "Wait for floating license" checkbox. However, this setting doesn't seem to be part of the project file.
Evgeni
lmutil lmstat -a -c port@server will let you see what the license server is up to
and that setting is not per project so its probably in:
~/.altera.quartus/quartus2.ini
though i doubt you need to tinker with it
I certainly don't want to write a script to parse all the output of "lmutil lmstat -a -c port@server", and that's probably not what Quartus GUI is doing either.
~/.altera.quartus/quartus2.ini contains "WAIT_FOR_LICENSE" setting. That's exactly what I needed to change (WAIT_FOR_LICENSE = on), and that seemed to solve the problem.
Thanks for the answer,
Evgeni
