17267 Discussions
Compilation error while compiling a variation of LPM_MUX in VHDL using precompiled libraries.
AOA00
We are using quartus 19.1 to generate a variation of LPM_MUX in VHDL. We are using Cadence INCISIV 15.20.020 to compile this. Using the "Launch Simulation Library Compiler", we were able to generate VHDL compiled libraries. A cds.lib was also generated which maps the libraries.
The generated LPM_MUX variation in VHDL is as below.
cyclone_lpm_mux.vhd
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY lpm;
USE lpm.lpm_components.all;
ENTITY cyclone_lpm_mux IS
       PORT
               data0          : IN STD_LOGIC ;
               data1          : IN STD_LOGIC ;
               sel            : IN STD_LOGIC ;
               result         : OUT STD_LOGIC
END cyclone_lpm_mux;
ARCHITECTURE SYN OF cyclone_lpm_mux IS
       --type STD_LOGIC_2D is array (NATURAL RANGE <>, NATURAL RANGE <>) of STD_LOGIC;
       SIGNAL sub_wire0       : STD_LOGIC_VECTOR (0 DOWNTO 0);
       SIGNAL sub_wire1       : STD_LOGIC ;
       SIGNAL sub_wire2       : STD_LOGIC ;
       SIGNAL sub_wire3       : STD_LOGIC_2D (1 DOWNTO 0, 0 DOWNTO 0);
       SIGNAL sub_wire4       : STD_LOGIC ;
       SIGNAL sub_wire5       : STD_LOGIC ;
       SIGNAL sub_wire6       : STD_LOGIC_VECTOR (0 DOWNTO 0);
BEGIN
       sub_wire4   <= data0;
       sub_wire1   <= sub_wire0(0);
       result   <= sub_wire1;
       sub_wire2   <= data1;
       sub_wire3(1, 0)   <= sub_wire2;
       sub_wire3(0, 0)   <= sub_wire4;
       sub_wire5   <= sel;
       sub_wire6(0)   <= sub_wire5;
       LPM_MUX_component : LPM_MUX
       GENERIC MAP (
               lpm_size => 2,
               lpm_type => "LPM_MUX",
               lpm_width => 1,
               lpm_widths => 1
       PORT MAP (
               data => sub_wire3,
               sel => sub_wire6,
               result => sub_wire0
END SYN;
No when we try compiling using the irun command
irun -compile -cdslib cds.lib -v93 cyclone_lpm_mux.vhd,
we get the error
ncvhdl_p: *E,SELLIB (cyclone_lpm_mux.vhd,42|7): unit (LPM_COMPONENTS) not found in library (LPM).
I did a grep on the compiled library generated by the quartus for lpm_components. It is not present there.
Can anyone let us know what is wrong.
RichardTanSY_Altera
May I suggest using the IES Simulation Setup Script Example? The script contains shell commands that compile the required libraries. The ncsim_setup.sh should be generated at the same directory with cds.libs.
There is another guide -To Perform A Simulation of a VHDL Design with command-line commands. Steps on how to compile the project files and libraries are stated.
Let me know if it helps.
