17268 Discussions
Compiling error: Couldn't open *.bc.xml for read!
beiwang2003
I was trying to compile multiple kernel files. Here are the steps I followed:
1. aoc -c kernel1.cl kernel2.cl
2. aoc -rtl -o allKernels.aocr kernel1.aoco kernel2.aoco
3. aoc allKernels.aocr
The first 2 steps were successfully. The compiling for the third step takes a long time, but returned the following error message at the end: Error: Coundn't open allKernels.bc.xml for read! In the allKernels folder generated from the second step, I could see kerenl2.bc.xml file, but not allKernels.bc.xml. My feeling is the way I compile multiple kernel files in a single *.aocx file as above might not be correct.
I am using Quartus 19.2.
Can you please advise? Thanks
beiwang2003
Now I am able to compile it successfully w/o the -o option. Here are the steps I followed:
2. aoc -rtl kernel1.cl kernel2.cl
3. aoc kernel2.aocr
It seems that -o option in the second step only renames the directory, but not the required file names within it (e.g., *.bc.xml etc). Now the question is how to use the -o option correctly for aoc -rtl so that both directory and file names are renamed?
AnilErinch_A_Intel
Hi Beiwang,
Can you provide a list of folders and files created in the working and non working case in each of the three steps .
So that we can compare the names.
Thanks and Regards
Anil
beiwang2003
The error is gone by switching to SDK 20.1. The earlier error came with the using of SDK 19.2.
AnilErinch_A_Intel
Thanks for letting the community know about the workaround.
Thanks and Regards
Anil
