17252 Discussions
Connecting DDR3 on ArriaII GX Development Kit
My design has an DDR3-Interface. Pin Assignment I copied from Referencedesign "a2gx125_qsys_pcie_gen1x4_11_0_1".
Fitter Works successfully, but I get a Critical Warning.
Can anyone help?
Thank you in advance
Critical Warning (185021):
Detected external clock signal directly connected to the RAM "q_sys:
u0|q_sys_cpu:cpu|q_sys_cpu_nios2_oci:
the_q_sys_cpu_nios2_oci|q_sys_cpu_nios2_ocimem:
the_q_sys_cpu_nios2_ocimem|q_sys_cpu_ociram_lpm_dram_bdp_component_module:
q_sys_cpu_ociram_lpm_dram_bdp_component|altsyncram:
the_altsyncram|altsyncram_14e2:auto_generated|q_a[0]" CLK0 port.
This connection may cause unexpected memory behavior if your external clock signal violates
the minimum pulse width specifications (clock high time and clock low time).
Using Quartus II 12.0. Same error with Stratix IV / DDR2 Controller
Project is from terasic QSYS 11.0 DDR2 Example. I only added a PCIe IP Core.
The DDR2 Controller has an 50 MHz(OSC_50_Bank3) input clock, no PLL. :(
Found on: quartushelp[.]atlera[.]com
ACTION: Use the on-chip phase-locked loop (PLL) as the input clock source to the memory block.
Strange. The example from terasic (DE4_DDR2_UniPHY) does not use a PLL as an input clock and it works without critical errors. why?
Edit:
Still doesn't work with PLL. :confused:
