17255 Discussions
Connecting HPS to FPGA DDR3 takes up all the address space
Using QSYS, I connected the HPS of a Cyclone V SOC to a DDR3 Controller on the fabric side via the HPS's H2F_AXI_MASTER bus.
The DDR3 Controller is assigned address: 0x0000_0000 to 0x3FFF_FFFF.
Now, when I try to connect another device to the HPS (over the same H2F_AXI_MASTER) - I get an address contention.
Using higher addresses generates the following error message:
--- Quote Start ---
Error: qsys.hps.h2f_axi_master: outside the master's address range (0x0..0x3fffffff)
--- Quote End ---
What is the address width of the H2F_AXI_MASTER bus ?
I can't find an element in the table that corresponds to the 0x0000_0000 - 0x3FFF_FFFF address range indicated by Qsys.
The first row in the table is The H2F_AXI_MASTER bus that you are inquiring about.
The addresses shown are from the ARM perspective.
The addresses within Qsys are from the FPGA perspective.
So for example:
1. If the HPS writes to its address 0xC000_0000 the data will appear in whatever is connected to address 0x0000_0000 on the FPGA ?
2. If the HPS writes to its address 0xC000_1000 the data will appear in whatever is connected to address 0x0000_1000 on the FPGA ?
Yes, 0xC0000000 is the fixed base address of the FPGA subsystem components accessed by the H2F_AXI_MASTER.
