I have a small CPLD project where one pin is connected to a register and also to some combinational logic, similar to the following code: library ieee; use ieee.std_logic_1164.all; entity test_max_delay is port ( CPU_WE : in std_logic; CPU_CLK : in std_logic; WE_comb : out std_logic; WE_reg : out std_logic ); end entity test_max_delay; architecture synthesis of test_max_delay is begin Reg : process (CPU_CLK) is begin if rising_edge(CPU_CLK) then WE_reg <= CPU_WE; end if; end process Reg; WE_comb <= CPU_WE; end architecture synthesis; Now I want to set up all three types of timing constraints: - Input setup & hold of CPU_WE relative to CPU_CLK - Clock to output for WE_reg - Propagation delay from CPU_WE to WE_reg When using the following constraints... set_time_format -unit ns -decimal_places 3 create_clock -name CPU_CLK -period 10.000 -waveform { 0.000 5.000 } [get_ports CPU_CLK] set_input_delay -max 7.5ns -clock "CPU_CLK" "CPU_WE" set_input_delay -min 1.0ns -clock "CPU_CLK" "CPU_WE" set_output_delay -clock "CPU_CLK" -max 2ns "WE_reg" set_output_delay -clock "CPU_CLK" -min 0ns "WE_reg" set_max_delay -from CPU_WE -to WE_comb 6ns set_min_delay -from CPU_WE -to WE_comb 0ns ...the input setup constraint from the registered path seems to be added to the actual propagation delay of the combinational path, i.e. input setup constraint: 7.5ns propagation delay constraint: 6.0ns actual propagation delay (CPU_WE to WE_comb): 4.631 Resulting slack: 6.0ns - (7.5ns + 4.631ns) = -6.131ns Is there any way to constrain the combinational path completely independent of the registered path or is there any reason why the input delay is added?Link Copied
If the starting point (CPU_WE) has a clocked delay (7.5 ns), then it will be added to the path.
Same thing for ending points. I don't really know why, but that's how set_max/min_delay are defined to work. There's probably a good reason.. And you can't just set_false_path -from [get_clock CPU_CLK] -to [get_ports WE_comb] because it will simply cut the path from CPU_WE to WE_comb. What you can do is add the 7.5 ns to your max delay constraint. Ie, set_max_delay -from CPU_WE -to WE_comb 13.5ns
