Hi there,
I have an array of registers that are 32 bit wide and need to be accessed in a different clock domain. So I wrote a process to cross those registers to the new clock domain by double-registering them:
cross_registers: process (rst, clk)
begin
if rst = '1' then
cnt_s <= (others => (others => '0'));
elsif rising_edge(clk) then
cnt_s <= cnt_s(0) & cnt;
new_cnt <= cnt_s(1);
end if;
end process cross_registers;
QII infers RAM in the implementation of this and defeated the purpose. So I added the following lines to prevent QII from doing this but to no avail. attribute ramstyle : string; attribute ramstyle of cnt_s : signal is "logic"; Any suggestions? Thanks, Hua
On a side note, I am not too sure about the code snippets above to be the proper way of crossing clock domain boundaries for vectors or arrays of vectors, I am thinking about the following is better, how do you think?
begin
if rst = '1' then
if cnt_s(0) = cnt_s(1) then
end if;
end if;
Doubling registering arrays will work to cross the boundary, but a FIFO would be more reliable.
You'll probably fnd quartus isnt infering a RAM, its infering an ALTSHIFTTAPS megafunction, which will use RAM, because all you have is a shift register.- Mark as New
--- Quote Start --- Doubling registering arrays will work to cross the boundary, but a FIFO would be more reliable. You'll probably fnd quartus isnt infering a RAM, its infering an ALTSHIFTTAPS megafunction, which will use RAM, because all you have is a shift register. --- Quote End --- Yeah, it was a memory block in the Altshifttaps megafunction (stratix iv) and it gave timing violations. I will use fifos instead. Thanks!
Are the clock domains asynchronous?
If they are not asynchronous, then there's no need for double registering -- and what Quartus did will work, assuming you've constrained them properly and TimeQuest gives a green flag. If they are asynchronous, you need to set a false path exception so Quartus will recognize them as synchronizers..- Mark as New
Yeah they are asynchronous. And instead of using fifos, I probably end up generating flag to indicate change of value, cross the flags over to the other side, and then latch them on the flag.
