17267 Discussions
Control how symbel (.bsf) file is created from verilog (.v) file in Quartus II
In using "Create symbol Files for current file" on my
cycloneIII_3c120_dev_niosII_standard_sopc.v, somehow
the behavior that the symbol is created changes.
I want to switch back to the old (before) way. But I do not know
how.
before: The ports for each sopc component (module)
locate in one isolated area (in the symbol) separated by
dotted lines. The dotted line are created automatically.
Only one bsf file (for current .v file) is created as the result of
the process.
now: Many bsf files (for all .v files under current .v file) are created.
In the top bsf file, all (in or out) ports for all sopc components are
together without separation by dotted line.
Anyone can help me on how to control the behavior of the operation?
gl888
By the way, I am using Quartus II V9.0 web edition.
I think quartus_map is used for this operation.
The two versions of symbol are attached. So you can
easily see the difference through the thumbnail images.
Once again, my question is how I can choose the
style of symbol file when creating it from verilog file.
gl888
