17263 Discussions
Convert Programming Files tool and multiple Nios processors
I'm trying to create a *.pof file for programming that host 2 configurations and 2 Nios, one for each configuration. The problem seems to be that the "Convert Programming Files" tool from Quartus only supports one *.hex file for one Nios core.
Is there an official way to do something like that? Maybe a document describing that?
It seems like the same problem does appear if you try to use 2 Nios in one configuration. How can I put the 2 Nios files in one *.pof?
Best Regards
Have a look at the "using the flash programmer from the command line" section in the nios ii flash programmer user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_nios2_flash_programmer.pdf). There's a section on "programming both hardware and software into an epcs/epcq device". Look through that. I think sof2flash, elf2flash & possibly bin2flash between them should solve your problem. These allow you to convert files and generate S-record files with offsets. You can then combine them and, if you wish, convert them to a .pof, or simply use the command line programmer.
Cheers,
Alex
Hi Alex, thanks I will look into that. But it doesn't look very comfortable.
I suppose there is no official way to do that?
That is an 'official' Altera document. So, Altera certainly support everything in there.
There are so many different uses for an EPCS/Q device and combinations of images that Altera can't possibly cover everything that everyone is going to want to do. Hence a document like this specifying what functions are available to create an image.
What you put in there, and where, is up to the user.
Cheers,
Alex
