17255 Discussions
Correct constrain (error 332060: "... was determined to be a clock but ...")
I have a warning that I want to disappear.
"s_synth_clk was determined to be a clock but was found without an associated clock assignment"
Yes, this is a clock. Does anyone here know how I "correctly" can constrain it (and make the warning disappear)?
syntclk : process(clk, reset, synth_div, synth_tacho_en)
begin
if (synth_tacho_en = "10") then --ENABLE
if reset = '1' then
s_synth_clk <= '0';
s_synth_cnt <= (others => '0');
elsif (rising_edge(clk)) then
s_synth_cnt <= s_synth_cnt + 1;
if (synth_div(7) = '1') then
s_synth_clk <= s_synth_cnt(7);
elsif (synth_div(6) = '1') then
s_synth_clk <= s_synth_cnt(6);
elsif (synth_div(5) = '1') then
s_synth_clk <= s_synth_cnt(5);
elsif (synth_div(4) = '1') then
s_synth_clk <= s_synth_cnt(4);
elsif (synth_div(3) = '1') then
s_synth_clk <= s_synth_cnt(3);
elsif (synth_div(2) = '1') then
s_synth_clk <= s_synth_cnt(2);
elsif (synth_div(1) = '1') then
s_synth_clk <= s_synth_cnt(1);
else
s_synth_clk <= s_synth_cnt(0);
end if;
end if; --CLK
else --NOT ENABLE
s_synth_clk <= '0';
end if;
end process;
synth_clk <= s_synth_clk;
Generating logic clocks like this is very bad practice in FPGAs. As are asynchronous enables.
You should generate clock enables instead - this will remove the warning.
OK, how do I do that and get the same functionality?
a clock enable would just go high for 1 clock in N cycles, depending on what division you wanted.
All you need is an edge detector for each counter bit. Then you'll get the same pattern you had before. Did you really want your clock to have a varying duty cycle?
