17265 Discussions
Creating Flip-flop by using logic gates
I am a student who new to VHDL and currently doing VHDL assignment. In this assignment, students are required to create the D, JK flip-flop.
I need help to solve my error for my code as shown as below:
library ieee;
use ieee.std_logic_1164.all;
entity Dflip_flop is
port
D :in std_logic;
clk :in std_logic;
Q :out std_logic;
Qbar :out std_logic
end Dflip_flop;
architecture hc of Dflip_flop is
signal W1 : std_logic;
signal W2 : std_logic;
signal W3 : std_logic;
signal W4 : std_logic;
signal W5 : std_logic;
begin
Q <= W4;
Qbar <= W5;
W1 <= not D;
W2 <= D nand clk;
W3 <= clk nand W1;
W4 <= W2 nand W5;
W5 <= W3 nand W4;
process(clk)
begin
if rising_edge(clk)then
Q <= D;
end if;
end process
end hc;
Error (10500): VHDL syntax error at Dflip_flop.vhd(41) near text "end"; expecting ";", or an identifier ("end" is a reserved keyword)
Can anyone point out what is the syntax error here??
Thanks and appreciated for the helps.
Besides that, i also faced a prob when designing the JK flip-flop.
In this assignment, students are required to simulate the result in the functional and timing mode..
By using the code as shown as below:
library ieee;
library work;
entity JKflip_flop is
port
J :in std_logic;
K :in std_logic;
clk :in std_logic;
Q :out std_logic;
Qbar :out std_logic
end JKflip_flop;
architecture hc of JKflip_flop is
signal W6 : std_logic;
begin
Q <= W3;
Qbar <= W4;
W1 <= not (J and clk and W4);
W2 <= not (K and clk and W3);
W3 <= W1 nand W4;
W4 <= W2 nand W3;
end hc;
It can only simulate only in the timing mode and it show nothing in the functional mode. I cant find a reason y this will happened??
Anyone knows y tis happened?? Did it need any settings in quartus to make so that it can simulate in the functional mode???
Thank you.
--- Quote Start ---
--- Quote End ---
first of all, you need a semicolon on the end of the "end process" line.
Second of all, you'll have problems with this, as Q has multiple drivers. Q is driven from the process, and from W3. Are you sure you want the process there?
For the second question, what are you similating with? have you written a testbench?
Hi Tricky,
For the 1st question, I will faced the Q is multiple drivers problem if i process there.. Actually i just wan to add on 1 statement in my coding which is " if rising_edge(clk) then
Q <= D" I just have a try to have a process statement in my coding and i don't know where should i put the process statement. Any suggestion??
For the 2nd question, testbench are not written. I just go the simulator settings to set the simulation mode to "functional" and start the vector waveform simulation.
--- Quote Start ---
--- Quote End ---
Keep the process - get rid of the logic version (or have a separate output for it). You description of a D-type with a process is correct.
--- Quote Start ---
--- Quote End ---
What simulator are you using?
There was a similar thread few days ago under the same topic "creating flipflops by using logic gates".
I will point out that your design defeats the purpose because you are not creating D flop from logic but you are inferring it at:
Q <= D;
thus you might not impress your professor...
