17254 Discussions
Crosspoint/crossbar switch ip
dicas3d
What's the easiest way to build a crosspoint switch on Arduino Mkr Vidor 4000 FPGA chip?
There's an IP Core?
Is to build it to 96 inputs and 96 outputs, audio applications with high performance with 0 latency and the highest possible audio resolution.
paveetirrasrie_Intel
Unfortunately we don't have any IP that support your requirement for now. You may visit Arduino Website to check the design availability that matches your protocol. Anyways, I have attached a RocketBoard link where I think it maybe useful for you.
https://www.rocketboards.org/foswiki/Projects/AudioSupportWithXillinuxForCycloneVSoC
Pavee
dicas3d
The link you provided is a project to add audio support incompatible with newer versions of Quartus.  To do a better understanding of what I want.
I will use an external DSP chip, external ADC/ADC a external TDM to usb codec. The FPGA will act as crosspoint/crossbar switch between them . And decomultiplex/multiplex TDM streams to the chip.
Good day to you.
Apologies but we don't have an IP that supports your requirement at the moment, at least not that I know of.
