- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Hello Forum Members,
I am using a DE0_CV, project generated by Terrasic Builder. I get the warning in the" I/O assignments report": "LEDR[0] Missing drive strength and slew rate." Another post on this forum indicates that this has something to do with the Current Strength and Slew rates not being defined in pin planner. However in Pin Planner the Current Strength and Slew rate for this pin have been defined. Any ideas would be appreciated. Best Regards, Johi.- Etiquetas:
- Intel® Quartus® Prime Software
Enlace copiado
2 Respuestas
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Solved:
Default settings in pin planner need to be changed to something else, this can be the same value but not default. Example: replace "16mA (default)" with "16mA" Johi.- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Yeah, the issue is that unless you explicitly set those assignments, they don't get written to the .qsf file, so you get the warning. You can just ignore the warnings.
Responder
Opciones de temas
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
