Custom Bridge?
I'm trying to create a custom bridge in SOPC builder.
I can't seem to find any information on how to change a component made in the Component Editor into a bridge, so the Nios2 reset/int vectors can be set to the memory on the OTHER side of the bridge.
The bridge itself works, but the problem is I cannot set the Nios 2 vectors to the on-chip RAM, and hence I cannot figure out how to generate the .DAT and .HEX files in Nios2 IDE for the memory on the other side of the bridge.
The "bridge" is actually a network-on-chip, which has its own interfaces and the like.
I believe you have to use the "set_port_property" command and the property you need to set is "bridgesToMaster". The value of the property is the name of your Avalon MM Master port.
Refer to the following:
http://www.altera.com/literature/hb/qts/qts_qii54022.pdf
http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
Jake
--- Quote Start ---
Jake
--- Quote End ---
Thank you, that is exactly what I'm looking for!
