17256 Discussions
Cyclone IV GX part support
I have just installed Quartus 10.0 in hopes of starting a project that will target a larger Cyclone IV GX device (EP4CGX150). It doesn't appear that version 10.0 supports any GX part other then the smallest.
Am I missing something here, I thought version 10.0 would add support for these devices. Any idea when the larger Cyclone IV GX parts will be supported?
If the device is not officially released yet, support will probably be added through a service pack once the timing is finalized for the device.
You should be able to get a "Hot-Fix" to add experimental support for the new device from altera, but you will have to open up a support case or push your rep to get the patch.
Pete
OK, Thanks. I've got a service request in on this.
