17255 Discussions
Cyclone V SOC kernel PLL error
Hello All
I am trying to execute kernel on Cyclone V SOC board. Host program and kernel are compiled ok
The kernel uses about 87% usage of the resource. But I am getting a PLL error after program FPGA.
Can you please give me some indications.
Error messages are below:
root@socfpga:~# export ALTERAOCLSDKROOT=/home/root/opencl_arm32_rte
root@socfpga:~# export AOCL_BOARD_PACKAGE_ROOT=$ALTERAOCLSDKROOT/board/c5soc
root@socfpga:~# export PATH=$ALTERAOCLSDKROOT/bin:$PATH
root@socfpga:~# export LD_LIBRARY_PATH=$ALTERAOCLSDKROOT/host/arm32/lib:$LD_ARY_PATH
root@socfpga:~# insmod $AOCL_BOARD_PACKAGE_ROOT/driver/aclsoc_drv.ko
root@socfpga:~/james# aocl program /dev/acl0 deformation.aocx
aocl program: Running reprogram from /home/root/opencl_arm32_rte/board/c5soc/arm32/bin
Reprogramming was successful!
root@socfpga:~/james# aocl diagnose
aocl diagnose: Running diagnostic from /home/root/opencl_arm32_rte/board/c5soc/arm32/bin
Verified that the kernel mode driver is installed on the host machine.
PLL Error: Read invalid pll setting for 196.608000 MHz. Make sure read access too acl_kernel_clk is functioning and the post-quartus-script succeeded
acl_hal_mmd.c:215:assert failure: Failed to read PLL configdiagnostic: acl_hal_mmd.c:215: l_try_device: Assertion `0' failed.
aocl diagnose: failed.
What version of the SDK are you using on your development PC and on your SoC (which has just the RTE)? Type "aocl version" on both.
--- Quote Start ---
--- Quote End ---
Hello pnac
Thanks a lot for your reply. The aocl version on my PC is 14.1 and on SOC is 14.0
I think that is the reason causing it. I will give it another try later today,
Will update the thread once I can confirm it
Thanks again!
--- Quote Start ---
--- Quote End ---
It works after the version is matched. Thanks pnac
