17249 Discussions
Cyclone V SoC not detected
Mahmoud_Hashem
I'm using:
Chameleon96 Cyclone V SoC FPGA
Windows 10
Quartus Standard 22.1.2
Programmer and Tools 22.1std.2.922
I've downloaded and installed Quartus Standard (evaluation license), Questa FE and the programmer.
Also, nstalled the drivers (the one at the end of the quartus and programmer setup).
When I connect the board to my PC, nothing shows up in the device manager, neither in the programmer.
I'm using the mini usb to usb a cable provided with the board.
I tried different usb ports on the PC, did not work.
And yes im using the right mini usb port in the board, the one beside the low speed connectors.
When i tried to connect the board to a laptop, which I've never installed anything related to FPGAs on it before, it shows up in the device manager under other devices as unspecified device.
Can someone help me to solve this problem?
Thanks in advance.
Mahmoud_Hashem
Problem solved. I was using USB 3.1 Gen 1 on the back panel of the motherboard. Now I used the USB 2.0 it is working.
Mahmoud_Hashem
EBERLAZARE_I_Intel
Glad you had it sorted out, just checking if you are facing any other issues related to this thread? I would try my best to help you on it.
EBERLAZARE_I_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
