DE2-115 Lab 1 Help
hi guys I just purchased the DE2-115 board and embarrassingly I have run into an error into the first lab itself:
We are supposed to implement a multiplexor so that the green LEDs mimic the input of either switches 0 - 7 or 8 - 15 based on the select input on switch 17. Heres my code; please tell me why only the x input is being passed perfectly to the green LEDs but when s is high only SW[8] is passed to the green LEDS from y inputs. Thanks!!!
Module TrialTwo (SW, LEDG, LEDR);
Input [17:0] SW;
Output [17:0] LEDR;
Output [7:0] LEDG;
Wire [7:0] x;
Wire [7:0] y;
Wire [7:0] m;
Wire s;
Assign x[7:0] = SW[7:0];
Assign x[7:0] = SW[15:8];
Assign s = SW[17];
Assign m = (~s&x) | (s&y);
Assign LEDG = m;
Assign LEDR = SW;
endmodule
--- Quote Start ---
Input [17:0] SW;
Output [17:0] LEDR;
Output [7:0] LEDG;
Wire [7:0] x;
Wire [7:0] y;
Wire [7:0] m;
Wire s;
Assign s = SW[17];
Assign LEDG = m;
Assign LEDR = SW;
endmodule
--- Quote End ---
you are not driving y but x is driven twice?
--- Quote Start ---
--- Quote End ---
eerrr right thanks lol
I have changed it so that x and y are both being driven yet the problem persists. Additionally I tried to do the 4th part of the same lab and no matter what inputs I give the 7-seg display shows all segments high. This problem persisted even after i changed the code so that the display should show six whatever the input. Is it possible I need to delete the old .sof file before recompiling or something? Heres my code, please help!:
module TrialTwoPointTwo (SW, LEDR, HEX0);
input [17:0] SW;
output [17:0] LEDR;
output [0:6] HEX0;
wire [2:0] m;
assign LEDR = SW;
mux3bit5to1 M0(SW[17:15], SW[14:12], SW[11:9], SW[8:6], SW[5:3], SW[2:0], m);
char7seg H0(m, HEX0_D);
endmodule
module mux3bit5to1(A, B, C, D, E, F, O);
input [2:0] A, B, C, D, E, F;
//input [3:0] KEY;
output [2:0] O;
wire [2:0] a1;
wire [2:0] b1;
wire [2:0] c1;
wire [2:0] d1;
wire [2:0] e1;
wire [2:0] f1;
wire [2:0] o1;
assign a1 = A;
assign b1 = B;
assign c1 = C;
assign d1 = D;
assign e1 = E;
assign f1 = F;
assign o1 = (~a1[0] & ~a1[1] & ~a1[2] & b1) | (~a1[0] & ~a1[1] & a1[2] & c1) | (~a1[0] & a1[1] & ~a1[2] & d1) | (~a1[0] & a1[1] & a1[2] & e1) | (~a1[0] & a1[1] & a1[2] & f1);
assign O = o1;
endmodule
module char7seg(c, Display);
input [2:0] c;
output [0:6] Display;
wire [0:6] Ini;
assign Ini[0] = 1'b1;//(~c[0] & ~c[1] & c[2])|(~c[0] & c[1] & c[2]);
assign Ini[1] = 1'b0;//(~c[0] & ~c[1] & ~c[2])|(~c[0] & c[1] & c[2]);
assign Ini[2] = 1'b1;//(~c[0] & ~c[1] & ~c[2])|(~c[0] & c[1] & c[2]);
assign Ini[3] = 1'b1;//(~c[0] & ~c[1] & c[2])|(~c[0] & c[1] & c[2]) | (~c[0] & c[1] & ~c[2]);
assign Ini[4] = 1'b1;//(~c[0] & ~c[1] & c[2])|(~c[0] & c[1] & c[2]) | (~c[0] & c[1] & ~c[2])|(~c[0] & ~c[1] & ~c[2]);
assign Ini[5] = 1'b1;//(~c[0] & ~c[1] & c[2])|(~c[0] & c[1] & c[2]) | (~c[0] & c[1] & ~c[2])|(~c[0] & ~c[1] & ~c[2]);
assign Ini[6] = 1'b1;//(~c[0] & ~c[1] & ~c[2])|(~c[0] & ~c[1] & c[2]);
assign Display[0:6] = Ini[0:6];
endmodule
as you can see in the above assignments to the Ini elements I muted the original code and replaced it with code to display the number 6 on the 7-seg but still no change
