17253 Discussions
DE2-70 SOPC SDRAM compile error
Hi.
I study with DE2-70 & "using the sdram memory on altera's de2-70 board
with verilog design" manual.
I practiced sopc & sdram example but i had some error messages as shown in the attached image.
I assigned the pin map by importing "de2-70 pin assignments.csv" file,
and coded verilog source file using pin node name.
please let me how can i solve this problem..
Thanks in advance.
https://www.alteraforum.com/forum/attachment.php?attachmentid=2873
https://www.alteraforum.com/forum/attachment.php?attachmentid=2874
I do not programm in Verilog, but from my understanding the datapins should be bidirectional?! (you can read it in the sopc description: "dq to and from the...") I think the instanciation for that in verilog is "inout [15:0] dram_dq;" perhaps give it a try, but I am not sure.
Have a nice day, Peter.
--- Quote Start ---
--- Quote End ---
I didn't find my mistake about "inout" & "input"..
Thanks for your apply!
