DS18b20+VHDL
Hi all,
I need a little help with my design,I would like connect sensor ds18b20 to the FPGA Altera DEOshematic.jpg I use the internal clock50MHz,I wrote some code but my design doesn't work.shows the maximum temperature , I did oscilloscope measurementsosc.jpg I have signal puls from the ds18b20. probably I wrote bad read and write slots time code.
I don't know how to improve it.
My code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
LIBRARY altera_mf;
USE altera_mf.all;
entity blok is
port
clk50m: in std_logic;
temper: out std_logic_vector(15 downto 0);
wireout: inout std_logic
end blok;
architecture Behavioral of blok is
type state_type is (s0,s1,s2,s3,s4,s5,s6,s7,w0,w3,w1,w2,read0,read1,r ead2,read3);
signal state: state_type;
signal temp: std_logic_vector( 15 downto 0);
signal reset: std_logic; --variable in time
signal i: integer range 0 to 50000000;
begin
temper<= temp;
process(clk50m)
variable j : integer range 0 to 15;
variable flag : integer range 0 to 60;
begin
if rising_edge(clk50m) then
case state is
when s0 => --initialization ds18b20
wireout<='0'; -- 0 on output
reset<='1';
state<=s1;
when s1 =>
reset<='0';
if(i=25000) then --wait 500us
wireout<='Z'; --Z on output
reset<='1';
state<=s2;
end if;
when s2 =>
reset<='0';
if (i=5000) then --wait 100us
reset<='1';
state<=s3;
end if;
when s3 =>
if(wireout='0') then --check signal from the ds18b20
state<=s4;
elsif(wireout='1') then --if none, back to top (s0)
state<=s0;
end if;
when s4 =>
reset<='0';
if(i=20000) then --wait 400us
reset<='1';
state<=s5;
end if;
when s5 => --
--sending a command CCxh
if (flag = 0 ) then flag:=1;state <=w0;
elsif (flag = 1 ) then flag:=2;state <=w0;
elsif (flag = 2 ) then flag:=3;state <=w2;wireout<='0';
elsif (flag = 3 ) then flag:=4;state <=w2;wireout<='0';
elsif (flag = 4 ) then flag:=5;state <=w0;
elsif (flag = 5 ) then flag:=6;state <=w0;
elsif (flag = 6 ) then flag:=7;state <=w2;wireout<='0';
elsif (flag = 7 ) then flag:=8;state <=w2;wireout<='0';
--sending a command 44xh
elsif (flag = 8 ) then flag:=9 ;state <=w0;
elsif (flag = 9 ) then flag:=10;state <=w0;
elsif (flag = 10 ) then flag:=11;state <=w2;wireout<='0';
elsif (flag = 11 ) then flag:=12;state <=w0;
elsif (flag = 12 ) then flag:=13;state <=w0;
elsif (flag = 13 ) then flag:=14;state <=w0;
elsif (flag = 14 ) then flag:=15;state <=w2;wireout<='0';
elsif (flag = 15 ) then flag:=16;state <=w0;
elsif (flag = 16 ) then flag:=20;state <=s6;wireout<='Z';
elsif (flag = 20 ) then flag:=21;state <=w0;
elsif (flag = 21 ) then flag:=22;state <=w0;
elsif (flag = 22 ) then flag:=23;state <=w2;wireout<='0';
elsif (flag = 23 ) then flag:=24;state <=w2;wireout<='0';
elsif (flag = 24 ) then flag:=25;state <=w0;
elsif (flag = 25 ) then flag:=26;state <=w0;
elsif (flag = 26 ) then flag:=27;state <=w2;wireout<='0';
elsif (flag = 27 ) then flag:=28;state <=w2;wireout<='0';
--sending a command BExh
elsif (flag = 28 ) then flag:=29;state <=w0;
elsif (flag = 29 ) then flag:=30;state <=w2;wireout<='0';
elsif (flag = 30 ) then flag:=31;state <=w2;wireout<='0';
elsif (flag = 31 ) then flag:=32;state <=w2;wireout<='0';
elsif (flag = 32 ) then flag:=33;state <=w2;wireout<='0';
elsif (flag = 33 ) then flag:=34;state <=w2;wireout<='0';
elsif (flag = 34 ) then flag:=35;state <=w0;
elsif (flag = 35 ) then flag:=36;state <=w2;wireout<='0';
--s7
elsif (flag = 36 ) then flag:=40;state <=s7;
end if;
when s6 =>
reset<='0';
if (i = 37500000 or wireout='1' ) then --wait 750ms
state <= s0;
reset<='1'; -- 1 on output
end if;
when s7 => --odczyt temperatury
if (flag = 40 ) then flag:=41; state<=read0;j:=0; wireout<='0';
elsif (flag = 41 ) then flag:=42; state<=read0;j:=1; wireout<='0';
elsif (flag = 42 ) then flag:=43; state<=read0;j:=2; wireout<='0';
elsif (flag = 43 ) then flag:=44; state<=read0;j:=3; wireout<='0';
elsif (flag = 44 ) then flag:=45; state<=read0;j:=4; wireout<='0';
elsif (flag = 45 ) then flag:=46; state<=read0;j:=5; wireout<='0';
elsif (flag = 46 ) then flag:=47; state<=read0;j:=6; wireout<='0';
elsif (flag = 47 ) then flag:=48; state<=read0;j:=7; wireout<='0';
elsif (flag = 48 ) then flag:=49; state<=read0;j:=8; wireout<='0';
elsif (flag = 49 ) then flag:=50; state<=read0;j:=9; wireout<='0';
elsif (flag = 50 ) then flag:=51; state<=read0;j:=10;wireout<='0';
elsif (flag = 51 ) then flag:=52; state<=read0;j:=11;wireout<='0';
elsif (flag = 52 ) then flag:=53; state<=read0;j:=12;wireout<='0';
elsif (flag = 53 ) then flag:=54; state<=read0;j:=13;wireout<='0';
elsif (flag = 54 ) then flag:=55; state<=read0;j:=14;wireout<='0';
elsif (flag = 55 ) then flag:=60; state<=read0;j:=15;wireout<='0';
elsif (flag = 60 ) then flag:=0;state<=s0;
end if;
--write
when w0 =>
wireout<='0'; --Set 0 to wireout
reset<='0';
if (i = 4000) then --wait 80us
wireout<='Z'; --Set Z to wireout
reset<='1';
state<=w1;
end if;
when w1 =>
state<=s5; --back after setting 1
when w2=>
state<=w3; --go to state w1
when w3 =>
wireout<='1'; --send 1
reset<='0';
reset<='1';
state<=s5;
end if;
--reading
when read0=>
state <= read1; --go to reading
when read1=>
wireout <= 'Z'; --Set Z to wireout
reset<='0';
if (i = 500) then --wait 10us
reset<='1';
state <= read2;
end if;
when read2=>
temp(j)<= wireout; --read bit temperature
state <= read3;
when read3=>
reset<='0';
if (i = 2750) then --wait 55us
reset<='1';
state <= s7;
end if;
when others =>
state <=s0;
end case;
end if;
end process;
process(clk50m,reset)
begin
if (reset='1')then
i<=0;
elsif rising_edge(clk50m) then
i<=i+1;
end if;
end process;
end Behavioral;
How did you test this code? have you written a testbench?
I only programming my boar DE0 and measured Inout signal in the oscilloscope ,The resulting vector was displayed in the diodes. I don't know where I got problem in my code..
Then I suggest writing a testbench and running simulations
I did testbench in ModelSim-Altera works well ,but in the real system isn't working.
How do you mean "Works well"? Does it follow the spec of the ds18b20?
--- Quote Start ---
--- Quote End ---
if your counter(i) is meant to go up to 50000000 then rollover then you are not doing that. You left it free running
yes it's true because I have clock 50MHz(20ns) but i have resest:
begin
if (reset='1')then
i<=0;
elsif rising_edge(clk1m) then
i<=i+1;
end if;
I think that did it well.
But when is that reset asserted? Is it before the counter gets to 50000000? In simulation, if it went over 50mil, you would get an error (but hardware will just roll over - creating a hardware simulation missmatch).
If you use signal tap and find the counter is going over 50mil, you need to go back and re-run your simulations.
