17253 Discussions
[DSE] Running a compilation on a remote farm through SSH
Hello. For quite some time I've been trying to setup a compilation in Design Space Explorer, using a remote farm and SSH (two windows and cygwins) over just an ethernet cable. I've been using this: http://quartushelp.altera.com/15.0/mergedProjects/optimize/dse/dse_pro_running_remote_comp_ssh.htm<br><br>Yet seems like no matter what I do, I always receive this error: [dse.png attachement] The 'cat' part means that the 'cat' command is not recognized but I can't fix it.
This is my setup, I've tried different things: [dse2.png attachement] Any idea what might be causing this? I've tried running the agent. When using SSH through cygwins, everything seems to be fine, encrypted keys or not. This is also new to me. Is there any detailed tutorial or a working example for this?
Your first post is too small to read - can you re-post?
Hey, I tried editing my post but after saving changes it just disappears... Idk what's wrong. I made two similar threads now so you should delete one I guess.
It got moderated. I've unlocked it now.
As it turns out I should have used putty plink as my DSE ssh client. I still don't have any idea why my CYGWIN won't work with DSE but it doesn't matter now
