Hello
I am synthetizing a FFT on Arria 10. The compiler report gives 136 DSP blocks are used including: 32 floating point multipliers 32 floating point addition of products 72 floating point adders (32+32+72=136) For me it does not add up because the same DSP blocks that do the multiplication, do as well the accumulation. So at maximum we should have 104 DSP blocks (32+72). how can we explain this result ?! Thanks in advance链接已复制
0 回复数
