17268 Discussions
Data memory using LPM_RAM_DQ
Hi all! I have a problem in using LPM_RAM_DQ to make a datamemory for MIPS Pipeline R3000. I've tried the following VHDL code :
entity data_memory is
    port ( clock : in std_logic;
         ALUoutM : in std_logic_vector (31 downto 0);
         writedataM : in std_logic_vector (31 downto 0);
         mymemwriteM : in std_logic;
         read_mem : out std_logic_vector (31 downto 0));
end data_memory;[/INDENT]
architecture behavior of data_memory is
COMPONENT lpm_ram_dq
    GENERIC (LPM_WIDTH: POSITIVE;
            LPM_TYPE: STRING := L_RAM_DQ;
            LPM_WIDTHAD: POSITIVE;
            LPM_NUMWORDS: natural := 0;
            LPM_FILE: STRING := "UNUSED";
            LPM_INDATA: STRING := "REGISTERED";
            LPM_ADDRESS_CONTROL: STRING := "REGISTERED";
            LPM_OUTDATA: STRING := "REGISTERED");
PORT (data: IN STD_LOGIC_VECTOR(LPM_WIDTH-1 DOWNTO 0);
address: IN STD_LOGIC_VECTOR(LPM_WIDTHAD-1 DOWNTO 0);
            we: IN STD_LOGIC := '1';
            inclock: IN STD_LOGIC := '1';
            outclock: IN STD_LOGIC := '1';
            q: OUT STD_LOGIC_VECTOR(LPM_WIDTH-1 DOWNTO 0));
END COMPONENT;[/INDENT]
signal tempdata : std_logic_vector (31 downto 0);
begin
label0: lpm_ram_dq
generic map (LPM_WIDTH                => 32,
                 LPM_WIDTHAD            => 32,
                 LPM_INDATA             => "REGISTERED",
                 LPM_OUTDATA             => "UNREGISTERED",
                 LPM_FILE                => "dmemory.mif"
                 LPM_ADDRESS_CONTROL => "unregistered")
port map ( address => ALUoutM,
                we => mymemwriteM,
                inclock => clock,
                data => writedataM,
                q => tempdata);
read_mem <= tempdata;[/INDENT]
end behavior;
[/INDENT]
However when I tried to compile it using QuartusII v8, the process seemed stuck at 2% and my memory usage increased alarmingly to 1.4 GB in my task manager.
Is there anything wrong with the above code? or is there any smarter way to realize a data memory.
Thanks in advance :)
address width of 32 bits means 2^32 ram depth each location at 32 bits.
i.e. trillion bits. Phenomenal size for fpga.
Ohh i see, so I won't be able to use lpm_ram_dq for realizing 32-bits address for a data memory? is there any alternative for it?
Use a smaller memory, with less address bits. You can still use a 32-bit address vector outside, and only map a small portion of the address space to the memory.
