Hello All,
I am currently doing a design where i have generated a pll using megawizard in Quartus 12.1 SP1, the pll generates 5 clk out of which clkout 1 which is -165 degree phase shift is used to latch SdrDQ data from a Sdram Interface (125 MHz interface) and pll outclock 4 is -105 degree phase shift is used to generate Sdram Clock. In first synthesis run when i generated using quartus the clock summary for sdrclk has .....FF_X88_Y1_N41 for SdrOe for arrival path summary assigned by tool. to reduce some slack i reduced the phase of outclock 1 and compiled , the slack didnt changed much but the same sdroe component in arrival path summary has DDIOOECELL_X67_Y0_N56 . My queries are 1) what is this DDIOOECELL ? although i tried to look for an answer couldnt get one. 2) how do FF changed to DDIOOECELL even though i have used the same QSF for second run? 3) how to remove this DDIOOECELL assignment from quartus , if anything to set in qsf file or like that? Hope for reply so that i can conclude my design- Tags:
- FPGA Design Tools
