17255 Discussions
Default run time won't stop increasing
Hi there,
I'm currently running Quartus II Version 13.0 sp1. While using the ModelSim-Altera to simulate waveforms I wanted to change the Default run time in
Simulate->Runtime options to 20 ns, which worked when I clicked apply and ok. Then when I went back to my waveform window none of the time increments
below had changed so I went back to check if it was still set now but when I went to clear it, it changed itself to ps no matter what I did now its boundlessly increasing in ps I try setting it and it just keeps increasing.
Its now at 15376000000000 ps as we speak, and I'm not sure if its something I've done or the software is causing it. Please let me know what I can do as I'm in the middle of a rather large assignment.
Cheers
