17267 Discussions
Deserialization 12 bits LVDS in a Cyclone III
I am using Quartus II 8.0 for programming a Cyclone III device. I have 2 LVDS clocks (fclk and lclk) an an 8 channel (12 bit) LVDS input that I wish to deserialize.
The megafunction for deserialization does not work for 12 bit data.
Will I program my component in VHDL to deserialize in 12 bits, or can I use some other components to make this (DDIO, multiplex,DFF...) ? I'm using SOPC Builder.
thanks
I can share a simple deserializer utilizing DDIO:
chan: FOR I IN 0 TO 7 GENERATE lvds_rcv : altddio_in GENERIC MAP ( intended_device_family => "Cyclone III", invert_input_clocks => "ON", lpm_type => "altddio_in", power_up_high => "OFF", width => 1) PORT MAP ( datain => AD9222_D(I TO I), inclock => fastclock, dataout_h => dataout_h(I DOWNTO I), dataout_l => dataout_l(I DOWNTO I)); PROCESS (fastclock) BEGIN IF rising_edge(fastclock) THEN lvds_sr(I) <= lvds_sr(I)(9 downto 0) & dataout_l(I) & dataout_h(I); END IF; END PROCESS; PROCESS (slowclock) BEGIN IF reset = '1' THEN lvds_rx(I) <= (others => '0'); ELSIF rising_edge(slowclock) THEN lvds_rx(I) <= lvds_sr(I); END IF; END PROCESS; END GENERATE;
i believe you can type 12 into the MegaWizard even though it doesn't have a pull down for this value.
Yes, that's true, if I remember right. I have my own deserializer, because I don't like the restrictions in phase setup of the "soft" LVDS MegaFunction and the strange RTL it offers for 14-Bit operation.
Thank you people.
But, if I program my own deser, I will need to desenvolve a driver for Nios ( I need to run the program in Nios for interface with a memory).
I need to edit a component of Mega Wizard and to try interface it, with a PIO for use it in Nios.
If I use the altlvds component with 2 channels and factor 6 ( width 12), I will have physically two inputs, and I need connect both in a same entrance, how I made this with no error in quartus ?
Factor 6 isn't correct. As thepancake suggested, you can simply type in a factor of 12 in the MegaWizard setup
