17253 Discussions
Detecting a tansition in a signal
This is my first post, hope I am doing things right
I have come across a situation which completely challenges my understanding of how and when the evaluation of signals in a process takes place.
The following snippit should explain my problem.
By the way, i am using Quartus Prime and the target is a DE2-115 board.
-- This was written to highlight a shortcoming in my understanding
-- about when signals are evaluated.
-- I expected the counter to only increment once the KEY input
-- turns from a '1' to a '0'
-- With KEY at a '1' level for some time, both KEY and PrevKEY will be at '1' levels.
-- Suppose that after the most recent clock cycle KEY turns to a '0'
-- At the next clock transition, surely KEY(0) will be a '0' and PrevKEY(0) would still be '1'
-- This should produce a single increment of the counter ????
-- what actually happens is that PrevKEY is totally ignored
-- the counter increments all the time while the key is a '0'
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.NUMERIC_STD.ALL;
entity Try is
port
CLOCK_50 : in std_logic; -- Generated by DE2 board
KEY : in std_logic_vector(3 downto 0); -- Four pushbutton keys on De2-115 board
LEDR : out std_logic_vector(17 downto 0) -- a group of red LEDs on the De2 board
end try;
architecture rtl of try is
-- signal Counter : integer range 0 to 7 := 0; -- I tried using an integer did not work either
signal Counter : std_logic_vector(2 downto 0); -- and also a std-logic_vector
signal PrevKEY : std_logic_vector(3 downto 0); -- this holds the previous value of the four keys
begin
process(CLOCK_50)
begin
if rising_edge(CLOCK_50) then
if KEY(0) <= '0' and PrevKEY(0) <= '1' then
Counter <= Counter + 1;
end if;
PrevKEY <= KEY;
end if;
end process;
-- LEDR(2 downto 0) <= std_logic_vector(to_unsigned(Counter, 3)); -- this was when I tried the integer
LEDR(2 downto 0) <= Counter;
end rtl;
Because you have used <= (less than or equal) in your compare, it is comparing a single bit to a single bit with a less than doesnt really mean much. KEY(0) <= '0' is always true when KEY = '0', and PrevKey <='1' is true when PrevKey is '0' or '1', so the equation can be reduced to:
if key(0) = '0' then counter <= counter + 1; end if;
PS. Have you debounced your keys elsewhere? you may get several increments of counter without debouncing the key presses.
As a beginner, I also recommend you get into the habit of not using std_logic_unsigned. It is a non standard VHDL package. Numeric std is the real IEEE standard.
Thanks very much for your response. It was a typo on my side, I accidentally typed the "<=" when it was supposed to be just a "=', but I never noticed it, no matter how long I looked at my code.
The reason I am using 4 keys as a vector is that they appear like that on the DE2-115 board and I was using the standard assignment file which came with the board.
The KEY signals are electronically debounced on the DE2 board.
Thanks too for the reminder about NUMERIC_STD. Will always use that in future.
Regards Stephen
