Discussion points....
Hi all,
So I've finalised my code for a uni project I'm studying. I'm currently writing up my report on how I developed my code and thought it would be good to end it with some discussion points/ideas for improvements. However because I'm new to VHDL I don't really know what possible points I could raise (I'm at the limit of my understanding!), and as I'm distance learning I don't really have anyone to bounce ideas off. I don't think I need to change my code as such, just discuss other options and say why they would have been better or worse. Does anyone have any suggestions?
The code just sets a simple repeating pattern of outputs based around an up-counter, I've pasted it below:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity seq is
port (clk : in std_logic;
enable : in std_logic;
reset : in std_logic;
a,b,c,d,e,f : out std_logic);
end;
architecture behaviour of seq is
signal count : integer range 0 to 5;
signal vector : std_logic_vector (5 downto 0);
begin
process(clk, enable, reset)
begin
if reset = '1' then
count <= 0;
elsif falling_edge (clk) then
if enable = '1' then
if count < 5 then
count <= count + 1;
case count is
when 0 => vector <= "001100";
when 1 | 5 => vector <= "011110";
when 2 | 4 => vector <= "110011";
when 3 => vector <= "100001";
end case;
else count <= 0;
end if;
end if;
end if;
end process;
a <= vector(5);
b <= vector(4);
c <= vector(3);
d <= vector(2);
e <= vector(1);
f <= vector(0);
end behaviour;
Points for improvement:
1. No Comments?
2. You have included an uneccesary librarys, std_logic_unsigned, which is also non-standard VHDL. Numeric_std (a standard library) is also unused.
3. a-f are a little undescriptive. What are they connected to? if its LEDS, wouldnt it be better to have an array led_out(5 downto 0) ?
Hi, thanks for the reply, I've taken your points on board. A big help!
you can clear the register 'vector' on reset.
