17252 Discussions
Driver Error :WEB_SERVER example
I am using Quartus and Nios 11 SP2 .
I am trying to run the Web_server demonstration example.
When I try to compile the example using NIOS2 IDE after importing the files, its showing me an error as ./drivers/inc/altera_avalon_tse.h:96:33: error: altera_avalon_sgdma.h: No such file or directory. Hence the compilation is failing.
I included the file and also imported all the files from the local drive to the project. But failed to compile the project.
Thanks for your help.
Subbu
Which hardware design are you using for the FPGA image? Is it a custom one or a ready made one? Does it have the SGDMA components for the Ethernet transfers?
