17258 Discussions
EDA Simulation Error: (vcom-7)
Christian_Lang
Hello together,
I downloaded the latest version from Quartus 24.3.
If I want to make the simulation of a testbench, I get the following error:
Can somebody help my, what does the error mean and how I can fix it?
Thanks in advanced.
KennyTan_Altera
May I know what are the Quartus version that you were using? Are you using Std or Pro edition of Quartus Prime?
RichardTanSY_Altera
The (vcom-7) error message indicates that a problem occurred while trying to open the specified file.
The problem is most likely due to the actual file being missing from the directory where the warning occurred, an incorrect or inaccessible file path, or perhaps insufficient permissions.
Please verify that the file exists, the directory path is correct, and that you have the necessary permissions to access the directory.
Richard Tan
KennyTan_Altera
Is there any more update for this case?
Christian_Lang
I can not find the file altera_syn_attributes.vhd at this folder. What could be the reason for that?
KennyTan_Altera
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
