I write a simple code by VHDL:
the top-level:-- USE LIBRARY IEEE 1164
library IEEE;
use IEEE.std_logic_1164.all;
entity A_gt_B is
port( inA, inB : in std_ulogic;
outC : out std_ulogic;
gt : in std_ulogic);
end entity A_gt_B;
architecture A_gt_B_Behavior of A_gt_B is
--conponent declaratrion
component my_inv
port( in1: in std_ulogic;
out1: out std_ulogic);
end component;
component my_nand2
port( in1,in2: in std_ulogic;
end component;
component my_nand3
port( in1,in2,in3: in std_ulogic;
end component;
--configuration specification
FOR ALL: my_inv use entity work.INV_gate(INV_behavior);
FOR ALL: my_nand2 use entity work.NAND2_gate(NAND2_behavior);
FOR ALL: my_nand3 use entity work.NAND3_gate(NAND3_behavior);
--signal declaraion
signal g1_to_g3, g2_to_g5, g3_to_g5, g4_to_g5: std_ulogic ;
begin
BAR_B: my_inv port map( inB, g1_to_g3);
A_NAND_B: my_nand2 port map( inA, g1_to_g3, g2_to_g5);
B_NAND_GT: my_nand2 port map( gt, g1_to_g3, g3_to_g5);
A_NAND_GT: my_nand2 port map( inA, gt, g4_to_g5);
NAND3: my_nand3 port map( g2_to_g5, g3_to_g5, g4_to_g5, outC);
end architecture A_gt_B_Behavior;
and the basic logic: -- USE LIBRARY IEEE 1164
library IEEE;
--use IEEE.std_logic_1164.all;
use ieee.std_logic_1164.all;
-- INV
entity INV_gate is
port( in1 : in std_ulogic;
end entity INV_gate;
architecture INV_behavior of INV_gate is
begin
out1 <= not in1 after 5ns;
end architecture INV_behavior;
-- NAND2
entity NAND2_gate is
port( in1, in2: in std_ulogic;
out1 : out std_ulogic);
end entity NAND2_gate;
architecture NAND2_behavior of NAND2_gate is
begin
out1 <= in1 nand in2 after 5ns;
end architecture NAND2_behavior;
-- NAND3
entity NAND3_gate is
port( in1, in2, in3 : in std_ulogic;
end entity NAND3_gate;
architecture NAND3_behavior of NAND3_gate is
begin
out1 <= not ( in1 and in2 and in3 )after 5ns;
end architecture NAND3_behavior;
when I compile it, it shows error message : Error (10482): VHDL error at basic_logic.vhd(57): object "std_ulogic" is used but not declared but in the first line I already declared the ieee library! who can tell me why :( p.s. Sorry, my English is a little weak > <
A VHDL compiler "forgets" about the included libraries between two entities or architectures (I don't remember which one). You must re-include the ieee library and ieee.std_logic_1164.all package before each entity.
It is usually recommended to put only one entity per file. Is there a reason why you use the unresolved std_ulogic type instead of the more usual std_logic?- Mark as New
--- Quote Start --- A VHDL compiler "forgets" about the included libraries between two entities or architectures (I don't remember which one). You must re-include the ieee library and ieee.std_logic_1164.all package before each entity. It is usually recommended to put only one entity per file. Is there a reason why you use the unresolved std_ulogic type instead of the more usual std_logic? --- Quote End --- There is one good reason - all multiple driver errors are picked up at compile time rather than elaboration. Ideally, everyone would use std_ulogic unless they were building a tri-state bus. The problem is everyone uses std_logic and so to avoid all the type casting, we all stick to one thing.
Thanks for your answers!:)
I try to put " library ieee;" and " use ieee.std_logic_1164.all; " before every entities, and compile successed! I started to learned VHDL recently, there are many different between VHDL and C/C++. In C/C++,it just includ library in the begin of code, but VHDL not. I was confused that did this problem just in QuartusII or in every VHDL compiler? Anyway, thanks a lot!!
