17241 Discussions
Early Power estimator Problem (Please help)
Steps taken,
I generated my VCD file modelsim
I even converted it to wlf to make sure it was right
Output from estimator:
I/O Thermal power dissipation 2605mW
Core Dynamic power 446mW
Static Power 112.38mW
module topmodule1(CLK,RST,en,Xin,en_ram1,ram1_we_addr,en_ram2,ram2_we_addr, out_ram2,in_ram2,rd_ram2,Yout);
input CLK;
input RST;
input en;
input [31:0] in_ram2;
input [31:0] Xin;
output reg [5:0] ram1_we_addr,ram2_we_addr;
output reg en_ram1, en_ram2,rd_ram2;
output reg [31:0] out_ram2;
output reg [31:0] Yout;
The addresses go to an external memory, and the "out_ram" are the datas from the external memory.
Attached are the pictures from the power analyzer
The power dissipated by the multpliers are 0. I am so confused because they synthesized (when I look at the number of multpliers).
Please help
Could it be that my VCD file is wrong?
I used the toggle rate 12.5% with no VCD file (toggle_rate.jpg)
then i set the toggle rate to 50% with no VCD filter (toggle_rate_50.jpg) and the values make better sense
