Eclipse Mars for Nios II
road_runner
I'm having a problem. Everything was working fine, but right now whenever I try and download the elf file to the board, I keep getting 'wsl not found'. Trying uninstall and reinstall, but if that doesn't work, I'm up against a tight deadline and need some options. Many thanks!
wwanalim_intel
Greetings and welcome to Intel's forum.
Please give me some time to check on this issue and will get back to you with the update.
Thank you.
Fathulnaim
wwanalim_intel
Hi Alex,
Did you follow all the steps here for the WSL installation on Windows and also run installation of additional distro packages required for Nios2 eds?
You can follow the steps and see the required command here on below link.
https://www.intel.com/content/www/us/en/docs/programmable/683525/21-3/installing-windows-subsystem-for-linux.html
Thank you.
Fathulnaim
wwanalim_intel
Is the issue resolved?
wwanalim_intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
