17255 Discussions
Error (10293) architecture "fsmd_arch" does not exist for entity "debounce"
Hi everybody, I try to compile a UART test circuit with debounce. But, when I simulate the code, the follow error appear:
Error (10293): VHDL error at uart_teste.vhd(6): architecture "fsmd_arch" does not exist for entity "debounce"
What is wrong in my code???
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity debounce is
port(
clk, reset: in std_logic;
sw: in std_logic;
db_level, db_tick: out std_logic
end debounce;
architecture exp_fsmd_arch of debounce is
constant N: integer:=21;
type state_type is (zero, wait0, one, wait1);
signal state_reg, state_next: state_type;
signal q_reg, q_next: unsigned(N-1 downto 0);
signal q_load, q_dec, q_zero: std_logic;
begin
process(clk,reset)
begin
if reset='1' then
state_reg <= zero;
q_reg <= (others=>'0');
elsif (clk'event and clk='1') then
state_reg <= state_next;
q_reg <= q_next;
end if;
end process;
q_next <= (others=>'1') when q_load='1' else
q_reg - 1 when q_dec='1' else
q_reg;
q_zero <= '1' when q_next=0 else '0';
process(state_reg,sw,q_zero)
begin
q_load <= '0';
q_dec <= '0';
db_tick <= '0';
state_next <= state_reg;
case state_reg is
when zero =>
db_level <= '0';
if (sw='1') then
state_next <= wait1;
q_load <= '1';
end if;
when wait1 =>
db_level <= '0';
if (sw='1') then
q_dec <= '1';
if (q_zero='1') then
state_next <= one;
db_tick <= '1';
end if;
else
state_next <= zero;
end if;
when one =>
db_level <= '1';
if (sw='0') then
state_next <= wait0;
q_load <= '1';
end if;
when wait0=>
db_level <= '1';
if (sw='0') then
q_dec <= '1';
state_next <= zero;
end if;
else
state_next <= one;
end if;
end case;
end process;
end exp_fsmd_arch;
library ieee;
entity uart_teste is
port(
btn: std_logic_vector(2 downto 0);
rx: in std_logic;
tx: out std_logic;
led: out std_logic_vector(7 downto 0);
sseg: out std_logic_vector(7 downto 0);
an: out std_logic_vector(3 downto 0)
end uart_teste;
architecture arch of uart_teste is
signal tx_full, rx_empty: std_logic;
signal rec_data, rec_data1: std_logic_vector(7 downto 0);
signal btn_tick: std_logic;
begin
--relacionando com núcleo uart
uart_unit: entity work.uart(str_arch)
port map(clk=>clk, reset=>reset, rd_uart=>btn_tick,
wr_uart=>btn_tick, rx=>rx, w_data=>rec_data1,
tx_full=>tx_full, rx_empty=>rx_empty,
r_data=>rec_data, tx=>tx);
-- relacionando com circuito debounce
btn_db_unit: entity work.debounce(fsmd_arch)
port map(clk=>clk, reset=>reset, sw=>btn(0),
db_level=>open, db_tick=>btn_tick);
-- incrementando loop de dados
rec_data1 <= std_logic_vector(unsigned(rec_data)+1);
-- led display
led <= rec_data;
an <= "1110";
sseg <= '1' & (not tx_full) & "11" & (not rx_empty) & "111";
end arch;
TO_BE_DONE
