17246 Discussions
Error (10430): VHDL Primary Unit Declaration:already exists in library "work"
Hi all,
in QuartusII web edition, I tried to compile a simple VHDL project and the result is this error message:
error (10430): vhdl primary unit declaration error at clk_div.vhd(56): primary unit "clkdiv" already exists in library "work"
this is my simple project:
library IEEE; use IEEE.std_logic_1164.all; entity CLKDIV is generic ( constant M : integer:=1 ); -- generic port ( reset_i, ref_clk_i, clk_i : in std_logic; clk_o, en_o : out std_logic ); -- port end CLKDIV; architecture CLKDIV_ARCH of CLKDIV is signal OutputVal : std_logic; begin MainProcess : process(reset_i, ref_clk_i) variable oldClkVal : std_logic; variable nPeriodsCount : integer range 0 to M-1; variable fSync : boolean; begin if reset_i='1' then oldClkVal:='0'; nPeriodsCount:=0; fSync:=false; OutputVal<='0'; en_o<='0'; elsif rising_edge(ref_clk_i) then en_o<='0'; if (clk_i/=oldClkVal and fSync) or (clk_i='1' and oldClkVal='0') then fSync:=true; if nPeriodsCount=0 then if OutputVal='0' then en_o<='1'; end if; nPeriodsCount:=M-1; OutputVal<=not OutputVal; else nPeriodsCount:=nPeriodsCount-1; end if; end if; oldClkVal:=clk_i; end if; end process MainProcess; clk_o<=OutputVal; end CLKDIV_ARCH;
where am I going wrong?
there is another file with an entity in it called CLKDIV in the project.
Ok, so I have to delete that file from the project directory?
Is that directory named "work" in quartus, even if it has another name in my PC?
Instead of deleting it, I would find out where the other CLKDIV is. How do you know another entity isnt using CLKDIV, and which one should it use?
Work is just the working library in the VHDL source. There isnt neccessarily a directory called work.
ok, thanks
I solved the problem, but now in this project there is another error:
critical warning: synopsys design constraints file file not found: 'clkdiv.sdc'. a synopsys design constraints file is required by the timequest timing analyzer to get proper timing constraints. without it, the compiler will not properly optimize the design.
Have I to create a .sdc file?
You dont have to create one. Without it, it will just tell you the max speed that each clock could theoretically run at. If you specify clock constraints, it can make the fitter work harder to actually acheive timing.
Ok, I've almost finished, I only have to solve some last problems :)
Now I have this error, regarding TimeQuet:
error: can't run timequest timing analyzer (quartus_sta) -- fitter (quartus_fit) failed or was not run. run the fitter (quartus_fit) successfully before running the timequest analyzer (create_timing_netlist).
Where am I going wrong?
Id have thought that error is fairly obvious.
Either you didnt run the fitter or there was a fit error.
