16642 Discussions
Error 10500: Syntax error
Hey guys this is my third VHDL project so forgive me if the answer is obvious:
When I compile my code I get the message
Error (10500): VHDL syntax error at ts.vhd(28) near text "/="; expecting "!", or "=>"
in reference to this line
When (s0)/=lm then
in this code
LIBRARY IEEE;
USE ieee.std_logic_1164.all;
Entity ts is
PORT ( reset : in std_logic;
q, z: out std_logic_vector(2 downto 0));
end ts;
Architecture arc of ts is
Type st1 is (s0, s1, s2);
signal lm: st1;
Type st2 is (t0,t1,t2);
signal mn: st2;
Begin
Process (reset)
Begin
if (reset = '1') then
lm <= s0;
elsif (reset = '0') then
Case lm is
When s0 => lm <= s1 after 2000000000 ns;
When s1 => lm <= s2 after 1000000000 ns;
When s2 => lm <= s0 after 3000000000 ns;
End case;
Case mn is
When (s0)/=lm then
mn <= t0;
When (s1 or s2)/=lm then
mn <= t1 after 1999999999 ns;
When t1 => mn <= t2 after 999999999 ns;
end case;
End If;
End Process;
With lm Select
q <= "110" When s0,
"011" When s1,
"010" When s2;
With mn Select
z <= "110" When t0,
"011" When t1,
"010" When t2;
End arc;
any ideas?
The problem is that you can't use the inequality operator within your case choice.
The choice must be a term that can be equated to the case expression.
If you want to make assignments to mn dependent on the state of lm then you could have something like
case lm is
when s0 =>
mn <= to;
when s1 =>
mn <= t1 etc
this my 1st project involve vhdl.this project,my supervisor wants me to use up3 board,receive 8 bit data from ADC, process it and display through visual basic(PC)..
this what i got so far..if the problems is too obvious,im still amateur bro..
1. i got error 10500 a lot
2. how to communicate up3 board using serial,did it still need vhdl code?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity up3_board is
port( datain_adc: IN STD_LOGIC_VECTOR(7 downto 0);
clock: IN STD_LOGIC; -- Clock Input from Altera Board
dataout_serial: OUT STD_LOGIC_VECTOR(7 downto 0));
end up3_board;
architecture BEHAVIOR of up3_board is
IF RISING_EDGE(clock) THEN
PROCESS(clock,datain_adc)
BEGIN
if datain_adc='00000000'--data from ADC,not correct yet..
then
dataout_serial<="00000000";--serial output in binary..not correct yet
elsif datain_adc='00000001'
then
dataout_serial<="00010000";
elsif datain_adc='00000010'
then
dataout_serial<="00010101";
elsif datain_adc='00000011'
then
dataout_serial<="00010110";
elsif datain_adc='00000100'
then
dataout_serial<="00010111";
elsif datain_adc='00000101'
then
dataout_serial<="00011000";
elsif datain_adc='00000110'
then
dataout_serial<="00011001";
elsif datain_adc='00000111'
then
dataout_serial<="00011010";
elsif datain_adc='00001000'
then
elsif datain_adc='00001001'
then
elsif datain_adc='00001010'
then
elsif datain_adc='00001011'
then
end process;
end BEHAVIOR;
You can't have an if outside the process, and you are missing a few end if's
Hi :) , plz any one can till me where is the error :( :( in this code" for circual Shifting Lift", the message error is "Error (10500): VHDL syntax error at modm.vhd(10) near text "begin"; expecting "end", or a declaration statement"
and the secone one
"Error (10500): VHDL syntax error at modm.vhd(33) near text "begin"; expecting "end", or a declaration statement"
library ieee;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use IEEE.std_logic_arith.all;
package crll is
function crl(s1:std_logic_vector;index:integer) return std_logic_vector;
end crll;
package body crll is
begin
process
function crl(s1:std_logic_vector;index:integer) return std_logic_vector is
variable z : std_logic_vector(s1'high downto s1'low);
begin
if(index >= s1'length) then
assert false
report "crl: rotate index is greater than variable length can't rotate" severity error;
end if;
if(index < 0) then
assert false
report "crl: rotate index is negative,can't rotate" severity error;
end if;
if(index = 0) then
z:=s1;
else
for jj in 1 to s1'high loop
z:= s1(s1'high-jj downto 0) & s1(s1'high downto s1'high-jj+1);
if(jj = index) then
exit;
end if;
end loop;
end if;
return z;
end crl;
begin
crl;
end process;
end crll;
Five lines in your code aren't legal VHDL syntax for a package and have to be removed (they are commented below):
package body crll is --begin --process function crl(s1:std_logic_vector;index:integer) return std_logic_vector is
end crl; --begin --crl; --end process; end crll;
I am very new at vhdl and so that &#305; wrote very simple code.
When &#305; compile my code, &#305; got Error (10500): VHDL syntax error at light.vhd(14) near text "END"; expecting ";" message.
I couldn't find what &#305; am doing wrong because &#305; use semicolon at line 14.
here is my code
LIBRARY ieee;
USE ieee.std_logic_1164;
ENTITY light IS
PORT (x1 , x2 : in std_logic;
f: out std_logic);
END ENTITY light ;
ARCHITECTURE logicfunction OF light IS
BEGIN
f <= (x1 and not x2) or (x2 and not x1)
END ARCHITECTURE logicfunction;
The errors usually tell you what the problem is - here you're missing a semicolon ;
and I suggest starting your own thread next time.
https://www.alteraforum.com/forum/attachment.php?attachmentid=7080
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 9.1 Build 222 10/21/2009 SJ Web Edition
Info: Processing started: Mon Mar 25 17:47:55 2013
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off DSP -c DSP
Error (10500): VHDL syntax error at DSP.vhd(21) near text "PORT"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at DSP.vhd(21) near text ";"; expecting "<="
Info: Found 0 design units, including 0 entities, in source file dsp.vhd
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 222 megabytes
Error: Processing ended: Mon Mar 25 17:47:56 2013
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 4 errors, 0 warnings
hey guys i need yer help
i don't know why these errors entered in this program and it driving me crazy
is anybody here to help me and solve my problem
and one more question. could answer this question
which CPLD or FPGA used for Ghz frequency ?
you make me glad if solve my problem thx a lot
--- Quote Start ---
--- Quote End ---
You need a label when doing an instantiation:label: componentName port map (...)
--- Quote Start ---
--- Quote End ---
none
