Error 10500
Hi, i have problems with my vhdl code.
This is the code:
LIBRARY IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use ieee.numeric_std.all;
ENTITY brake_var IS
port (
clk : in std_logic;
reset : in std_logic;
chip_select : in std_logic;
writedata : in std_logic_vector (31 downto 0);
write_n : in std_logic;
address : in std_logic;
readdata : out std_logic_vector (31 downto 0);
out_port1 : out std_logic_vector (7 downto 0);
out_port2 : out std_logic_vector (7 downto 0));
END brake_var;
ARCHITECTURE brake_system OF brake_var IS
signal D : unsigned (31 downto 0); -- distance d'arrêt
signal v : unsigned (31 downto 0); -- vitesse du véhicule
signal Dmax : unsigned (31 downto 0); -- vitesse max (danger)
signal tb : std_logic;
signal brake : std_logic;
BEGIN
readdata <= std_logic_vector(D) when address = '0' else std_logic_vector(v);
registers: PROCESS (clk, reset)
BEGIN
if reset = '0' then
D <= (others =>'0');
v <= (others =>'0');
elsif clk'event and clk = '1' then
if chip_select ='1' and write_n = '0' then
if address = '0' then
D (31 downto 0) <= unsigned(writedata (31 downto 0));
else v (15 downto 0) <= unsigned(writedata (15 downto 0));
end if;
end if;
end if;
END PROCESS;
distance : PROCESS (clk,reset)
begin
if reset = '0' then
elsif clk'event and clk='1' then
D(31 downto 0) <= (v(15 downto 0)*3)/10 + (v(15 downto 0)*v(15 downto 0))/100;
else
end if;
END PROCESS;
tableau_de_bord : PROCESS (clk,reset)
begin
if reset = '0' then
tb <= '0';
tb <= '0' when D < Dmax else
'1' when D > Dmax;
end if;
end process;
frein : PROCESS (clk,reset)
begin
if reset = '0' then
brake <= '0';
brake <= '0' when tb = '0' else
'1' when tb ='1';-- freinage
end if;
END PROCESS;
out_port1 <= (others=> tb);
out_port2 <= (others=> brake);
END brake_system ;
And the error :
Error (10500): VHDL syntax error at ppp.vhd(61) near text "when"; expecting ";"
Error (10500): VHDL syntax error at ppp.vhd(71) near text "when"; expecting ";"
Error: Quartus II 32-bit Analyze Current File was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 329 megabytes
Error: Processing ended: Sun May 25 19:34:03 2014
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:03
Help me please it's urgent.
I gave you the widths of each stage
testing ...
Critical Warning (332148): Timing requirements not met
same 3 errors persisting ><
--- Quote Start ---
--- Quote End ---
what? three multipliers and a tiny bit of logic failing speed.
What device are you using, what speed (I believe it is 50MHz). Even a design done in the kitchen can achieve such speed.
where is your best code.
Are you sure that the clock in your process is actually the one that you constrained, or driven by a pll connected to the clock you constrained?
If you are using a PLL, what frequency did you define for your design?
does any one have skype ?
(my pseudo is latrous 92 )
it would be more appropriate to explain to me if it doesnt distrurb :)
thank you for your help
