Error 10500
Hi, i have problems with my vhdl code.
This is the code:
LIBRARY IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use ieee.numeric_std.all;
ENTITY brake_var IS
port (
clk : in std_logic;
reset : in std_logic;
chip_select : in std_logic;
writedata : in std_logic_vector (31 downto 0);
write_n : in std_logic;
address : in std_logic;
readdata : out std_logic_vector (31 downto 0);
out_port1 : out std_logic_vector (7 downto 0);
out_port2 : out std_logic_vector (7 downto 0));
END brake_var;
ARCHITECTURE brake_system OF brake_var IS
signal D : unsigned (31 downto 0); -- distance d'arrêt
signal v : unsigned (31 downto 0); -- vitesse du véhicule
signal Dmax : unsigned (31 downto 0); -- vitesse max (danger)
signal tb : std_logic;
signal brake : std_logic;
BEGIN
readdata <= std_logic_vector(D) when address = '0' else std_logic_vector(v);
registers: PROCESS (clk, reset)
BEGIN
if reset = '0' then
D <= (others =>'0');
v <= (others =>'0');
elsif clk'event and clk = '1' then
if chip_select ='1' and write_n = '0' then
if address = '0' then
D (31 downto 0) <= unsigned(writedata (31 downto 0));
else v (15 downto 0) <= unsigned(writedata (15 downto 0));
end if;
end if;
end if;
END PROCESS;
distance : PROCESS (clk,reset)
begin
if reset = '0' then
elsif clk'event and clk='1' then
D(31 downto 0) <= (v(15 downto 0)*3)/10 + (v(15 downto 0)*v(15 downto 0))/100;
else
end if;
END PROCESS;
tableau_de_bord : PROCESS (clk,reset)
begin
if reset = '0' then
tb <= '0';
tb <= '0' when D < Dmax else
'1' when D > Dmax;
end if;
end process;
frein : PROCESS (clk,reset)
begin
if reset = '0' then
brake <= '0';
brake <= '0' when tb = '0' else
'1' when tb ='1';-- freinage
end if;
END PROCESS;
out_port1 <= (others=> tb);
out_port2 <= (others=> brake);
END brake_system ;
And the error :
Error (10500): VHDL syntax error at ppp.vhd(61) near text "when"; expecting ";"
Error (10500): VHDL syntax error at ppp.vhd(71) near text "when"; expecting ";"
Error: Quartus II 32-bit Analyze Current File was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 329 megabytes
Error: Processing ended: Sun May 25 19:34:03 2014
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:03
Help me please it's urgent.
like that ?
LIBRARY IEEE;
ENTITY brake_var IS
port (
clk : in std_logic;
END brake_var;
BEGIN
BEGIN
if reset = '0' then
tb <= '0';
brake <= '0';
--D (31 downto 0) <= unsigned(writedata (31 downto 0));
end if;
end if;
if D > Dmax then
tb <= '0';
elsif D < Dmax then
tb <= '1';
end if;
if tb = '0' then
brake <= '0';
elsif tb = '1' then
brake <= '1';
end if;
end if;
END PROCESS;
END brake_system ;
this one below compiles but I haven't a clue what is it doing.
LIBRARY IEEE; use IEEE.std_logic_1164.all; use ieee.numeric_std.all; ENTITY brake_var IS port ( clk : in std_logic; reset : in std_logic; chip_select : in std_logic; writedata : in std_logic_vector (31 downto 0); write_n : in std_logic; address : in std_logic; readdata : out std_logic_vector (31 downto 0); out_port1 : out std_logic_vector (7 downto 0); out_port2 : out std_logic_vector (7 downto 0) ); END brake_var; ARCHITECTURE brake_system OF brake_var IS signal D : unsigned (31 downto 0); -- distance d'arrêt signal v : unsigned (31 downto 0); -- vitesse du véhicule signal Dmax : unsigned (31 downto 0); -- vitesse max (danger) signal tb : std_logic; signal brake : std_logic; BEGIN readdata <= std_logic_vector(D) when address = '0' else std_logic_vector(v); registers: PROCESS (clk, reset) BEGIN if reset = '0' then D <= (others => '0'); v <= (others =>'0'); tb <= '0'; brake <= '0'; elsif clk'event and clk = '1' then if chip_select ='1' and write_n = '0' then if address = '0' then D(31 downto 0) <= unsigned(writedata (31 downto 0)); v(15 downto 0) <= unsigned(writedata (15 downto 0)); else D(31 downto 0) <= (v(15 downto 0)*3)/10 + (v(15 downto 0)*v(15 downto 0))/100; end if; end if; if D > Dmax then tb <= '0'; elsif D < Dmax then tb <= '1'; end if; if tb = '0' then brake <= '0'; elsif tb = '1' then brake <= '1'; end if; end if; END PROCESS; out_port1 <= (others=> tb); out_port2 <= (others=> brake); END brake_system ;
and simplified as below. read my comments please.
LIBRARY IEEE; use IEEE.std_logic_1164.all; use ieee.numeric_std.all; ENTITY brake_var IS port ( clk : in std_logic; reset : in std_logic; chip_select : in std_logic; writedata : in std_logic_vector (31 downto 0); write_n : in std_logic; address : in std_logic; readdata : out std_logic_vector (31 downto 0); out_port1 : out std_logic_vector (7 downto 0); out_port2 : out std_logic_vector (7 downto 0) ); END brake_var; ARCHITECTURE brake_system OF brake_var IS signal D : unsigned (31 downto 0); -- distance d'arrêt signal v : unsigned (31 downto 0); -- vitesse du véhicule signal Dmax : unsigned (31 downto 0); -- vitesse max (danger) signal tb : std_logic; signal brake : std_logic; BEGIN readdata <= std_logic_vector(D) when address = '0' else std_logic_vector(v); registers: PROCESS (clk, reset) BEGIN if reset = '0' then D <= (others => '0'); v <= (others =>'0'); tb <= '0'; elsif clk'event and clk = '1' then if chip_select ='1' and write_n = '0' then if address = '0' then D <= unsigned(writedata); v(15 downto 0) <= unsigned(writedata (15 downto 0)); -- what about v(31:16) -- so v takes same data as D but for 16 LSBs? else D <= (v(15 downto 0)*3)/10 + (v(15 downto 0)*v(15 downto 0))/100; end if; end if; if D > Dmax then tb <= '0'; else tb <= '1'; end if; end if; END PROCESS; brake <= tb; -- ? out_port1 <= (others=> tb); out_port2 <= (others=> brake); END brake_system ;
i changed like that :
LIBRARY IEEE;
ENTITY brake_var IS
port (
clk : in std_logic;
END brake_var;
BEGIN
readdata <= std_logic_vector(v) when address = '0';
BEGIN
if reset = '0' then
tb <= '0';
brake <= '0';
end if;
end if;
if D > Dmax then
tb <= '0';
elsif D < Dmax then
tb <= '1';
end if;
if tb = '0' then
brake <= '0';
elsif tb = '1' then
brake <= '1';
end if;
end if;
END PROCESS;
END brake_system ;
got 3 critical errors
Critical Warning (332148): Timing requirements not met
so your velocity is actually 16 bits coming when address is 0.
Then you compute D from it (rather than acquire it from read data.Looks like some braking possible.
The main bottleneck to timing is your divider and multipliers in one single algebra.
You can't do algebra in code.
Moreover have you got sdc file for timing constraints so that the tool knows about your speed.
what sould i do to calculate Distance D then ?
v*3 can be converted to addition (v+v+v).
v*v keep it
get each one prrior to division e.g.
res1 <= v+v+v;
res2 <= v*v
convert division to multiplication (optional) since it is divide by constant i.e. scale 10 (or 100) so that it becomes power of 2. If I multiply 10 * 2^15/10 I get
2^15 so use 2^15/10 (i.e. 3277) as mult factor then discard 15 lsbs from result.
also notice you can rearrange formual as below if you wish:
(v+v+v + v*v/10)/10;
or
(v*30 + v*v)/100;
then do division as I explained
but v should be declared as 16 bits (not 32 bits)
LIBRARY IEEE;
ENTITY brake_var IS
port (
clk : in std_logic;
END brake_var;
BEGIN
BEGIN
if reset = '0' then
tb <= '0';
brake <= '0';
D(31 downto 0) <= (v(15 downto 0)+v(15 downto 0)+v(15 downto 0))/10 + (v(15 downto 0)*v(15 downto 0))/100;
end if;
end if;
if D > Dmax then
tb <= '0';
elsif D < Dmax then
tb <= '1';
end if;
if tb = '0' then
brake <= '0';
elsif tb = '1' then
brake <= '1';
end if;
end if;
END PROCESS;
END brake_system ;
gave me the same 3 critcal warnings ?
how to convert from division to multiplication in my situation ?
Before this diving, do you have sdc file for timing constraints?
I think best formula for you is this:
D = (v*30 + v*v)/100
two multipliers to get result then one mult for division by 100.
multiply result by 32768/100 i.e. by 328 then discard 15 lsbs from result of mult
yes i have this sdc file :
create_clock -name {CLOCK_50} -period 20.000 -waveform { 0.000 10.000 } [get_ports {CLOCK_50}]
derive_pll_clocks
derive_clock_uncertainty
It removed 3 critical warnings but those 3 critical warnings persist:
I modified D like you said.
1) why v is 32 bits when you only deal with 16 bits?
2) did you convert division to mult
i changed v to 16
and honestly i don't know how to change division :/
well division is obviously just division but you can convert it to mult/div by truncation i.e. once you get v*30 + v*v result then just do the following:
multiply result by 328
discard 15 lsbs
done
well multiply result by 328 is clear but
what how to discard 15 lsbs ?
--- Quote Start ---
--- Quote End ---
result_divided <= result(n downto 15);
I probably will have nightmares of car braking failure tonight...
hahahahahaha :p :p
sir we still students :)
so it should be like this ?
result<=(v*30 + v*v)*328 ;
result_divided <= result (31 down to 15)
--- Quote Start ---
hahahahahaha :p :p
--- Quote End ---
correct. if you still get timing violation then break it up into stages:
res1 <= v*30; -- 16 bits * 5 bits => 21 bits
res2 <= v*v; -- 16 bits * 16 bits => 32 bits
res3 <= res1 + res2; -- 21 bits + 32 bits => 33 bits
res4 <= res3 *328; -- 33 bits * 9 bits => 42 bits
D <= res4(41 downto 15); -- 27 bits only
so according to this D needs only be 27 bits (if I my math is right)
or i'm wrong? i don't know i'm really confused :(
excuse me
and for result type ? it should be 32 ?
