Error 10500
I'm trying to make a magnitude comparator in VHDL. When I try to compile it, I get:
"Error (10500): VHDL syntax error at mag_comp.vhd(15) near text "AGTB"; expecting ";"
I followed the directions and looked at line 15, but there isn't anything there that needs to be done.
Here's what I have typed out:
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY mag_comp IS PORT ( a2, b2, a1, b1, a0, b0 :IN STD_LOGIC; AEQB, AGTB, ALTB :OUT STD_LOGIC); END mag_comp; ARCHITECTURE behavior OF mag_comp IS BEGIN PROCESS (a2, b2, a1, b1, a0, b0) BEGIN IF (a2 > b2) THEN AEQB <= '0' AGTB <= '1' ALTB <= '0' ELSIF (a2 < b2) THEN AEQB <= '0' AGTB <= '0' ALTB <= '1' ELSE (a2 = b2) THEN AEQB <= '1' AGTB <= '0' ALTB <= '0' IF (a1 > b1) THEN AEQB <= '0' AGTB <= '1' ALTB <= '0' ELSIF (a1 < b1) THEN AEQB <= '0' AGTB <= '0' ALTB <= '1' ELSE (a1 = b1) THEN AEQB <= '1' AGTB <= '0' ALTB <= '0' IF (a0 > b0) THEN AEQB = '0' AGTB = '1' ALTB = '0' ELSIF (a0 < b0) THEN AEQB = '0' AGTB = '0' ALTB = '1' END IF; END PROCESS; END behavior;I'm not sure if I've done anything wrong, I'm kind of sketchy when it comes to VHDL.
LIBRARY ieee;
ENTITY mag_comp IS
AEQB:OUT STD_LOGIC;
AGTB:OUT STD_LOGIC;
ALTB:OUT STD_LOGIC
END mag_comp;
You forgot a lot of end-of-line semicolons and a few closing 'end if;'
I'm don't think you can compare std_logic (<, >) except for equality (=, /=).
