17254 Discussions
Error (10822) a code that dosent work
i will be thankful if somebody will can help me..my aim is to make a block that get 3 inputs:a clc that change every 0.1 seca input that get '1' every time i press key0and reset button that reset my countthe aim is to count the number of time i press and when there is 3 secs that i dont press i get the count of the time i pressedi tried to it with this code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity CLAPNUM is
port(
resetN, clk : in std_logic;
key0 : in std_logic ;
sinus : out std_logic_vector(4 downto 0));
end CLAPNUM ;
architecture arc_CLAPNUM of CLAPNUM is
signal countera : std_logic_vector(4 downto 0) :="00000" ;
signal counterb : std_logic_vector(4 downto 0) :="00000" ;
signal cinout : std_logic := '0' ;
signal moda : std_logic := '0' ;
begin
process ( resetN key0, clk)
begin
if resetN = '0' then
countera<="00000" ;
counterb<="11110";
elsif (key0 ='1') and moda='0' then
countera<= countera+"00001" ;
counterb<="11110";
elsif (rising_edge(clk)) then
if counterb/="00000" and (key0 ='0') then
counterb <= counterb-"00001";
else
moda <= '1';
end if;
elsif moda='1' then
sinus<= countera;
end if;
end process;
end arc_CLAPNUM;
but clearly it dosent work...can someone help me plz?
Yes- because you have control signal attempting to do increment a counter not on a clock edge.
You need to follow this template:
process(resetN, clk) begin if resetN = '0' then --do resets here elsif rising_edge(clk) --ALL other code goes in here end if; end process;
If you dont follow the template above, you are trying to create extra analogue control paths. For example - if key0 = '1' and moda = '0', it is trying to increment the counter an infinite number of times in 0 time (in reality there will be some tiny propogation delay - still it will count up ALOT). This is an analogue feedback path - and is not a good idea.
I suggest you draw your circuit on paper before you try and write the code. Then when you have a good idea of the circuit, you can use the known templates to copy your circuit into code.
I also suggest you write a testbench to test the code.
